Hi all.
I'm a newcomer to the FTA stuff and I've been reading these posts for about 11 hours straight (well I did eat a little), and anyways I think I have digested enough info to finally ask some pointed questions.
My goal is to have a FTA motorized system that also incorporates my VHF/UHF antenna and feeds the combined Sat/Ant signals into my (soon to be defunct) cable box which has cable already running to 4 different rooms in my house. This is will hopefully feel almost like cable to all in the house which is what I think most families want to achieve.
Any thoughts?
Well here's a guess by me…..
Let's start with a hypothetical system consisting of a 36" Wineguard Dish with a Fortec Stab HH90 motor and a Pansat 2700a receiver.
Now I realize that when the dish gets moved to a different satellite that all receivers in the house will only have the channels on that satellite to choose from. But from what I have read it seems possible to tune into more than one Satellite at a time by either adding more LNBs (The Satellites have to be close together) or more Dishes (Which is really just another LNB when you get right down to it). Or, you could perhaps tune into more than one polarity at a time with a dual LNB and receive more channels without moving the dish. (Is this correct?)
To allow more than one receiver appears to be the most complicated part of it all. I have seen some pretty convoluted examples. But as far as I can tell a simple solution would be to use a 3x4 Multiswitch that has inputs for the dual outputs from a dual LNB (Or a 5x4 switch for Quad LNBs) and the single feed from the VHF/UHF antenna. This Multiswitch could then feed the 4 cables in my exterior cable box and then from there either to a Diplexor and Receiver or simply to a Terminator. The "Channel Master 6344P Multiswitch", seems to fit the bill. (Is this correct?)
One other thought: Can the cables running through my house from the cable box handle the signal? I would use RG6 cable for my part of the install but there are no guarantees that the existing cable will be up to snuff....
FYI: BY cable box I mean that little weatherproof box on the outside of the house that my main cablevision feed runs into and is split to 4 lines running through the walls of my house to different rooms.
I will stop here and post new questions based upon the answers to the above statements...
Cheers All :up
Any thoughts?
Cheers All :up
