Multiple T.V.'s
delawareneck
15
Lower Delaware
I'm thinking of bringing back to life a BUD that came with the house I bought. Is there a way to hook up 5 or more t.v's to 1 dish and have all t.v.'s on a different channel?
A special thanks to XXTORNXX for recomending this site. I've had some good reading.
yes. You need 5 receivers if all are viewing different channels.
And then you will need a voltage controlled lnbf(dual).
And Last you will need a multi-switch.
That should do it.:up
Thanks delawareneck you got question the members here are very knowledgeable this is the best site out there for all you needs and check out the sponsors.Post some pics of lnb and motor
A bandstacked C band like the Eagle Aspen Sadoun has up for sale and a couple of DP34 multi switches will feed up to 8 recievers, and you still have two extra input ports for additional lnb's
Actually you don't need the DP34 with the B1Sat Bandstacker C-Band LNBF. You can just use a high frequency splitter to split the signal to multiple receivers. This is a much cheaper solution. Saving money is one advantage of having a bandstacked LNBF.
This one will do:
Sadoun that is a sweet splitter you got me interested how much$? i got some 2 way 2-2300mhz perfect vision from you no problems with your equipment.
That 6-Way splitter is $12. We have 2-Way,4-Way,6-Way,8-Way
Notice the frequency range on this one is 5-2400 mhz. All ports powered. Diode protected on each port.
