My sat setup (grounding & Lnb questions)
scottc98
1,342
Columbus, OH
Hey everyone,
I've had an existing FTA for many years now and have finally got around to laying it out on paper. After reviewing it, I was starting to wonder if I have everything properly set up grounding-wise. The system has not caused me any issues expect for one failed Disqec, a bad BSC621, and the occasional realignment due to weather. Hoping people here can take a look and maybe suggest a few things that I missed on the installation.
Here are my main questions:
1) Is my grounding correct or am I missing some pts (i.e switches)
2) Thinking of switching the two KU standard LNBS with Dish stacked lnbs to open a few ports up. Where would you put the two extra LNBS at? (Can only be between 72 and 112 on the T90)
3) Now that IS-9 KU is pretty much dead now, any ideas on what to do with this dish? (View is only between 50ish to 82/83 at its current location)
Thanks in advance :)
Scott, your grounding looks correct - the ground block should be within 10 feet of the entrance to the house.:)
Bob
Captive Works signal meter
problem with switching &/or CS4000
