Need Help with 1000.2
jdodson
Sep 17, 2005
25
I have all of the satellites confirmed, 119, 110, 129,, but when you cancel out and go through your checks, it stays at 0 of 5
hawker152
357
Kansas
Signal is way to low. Needs to be atleast 60 at the lowest. Mines in the 80s. Maybe a tree is growing in the way or you had a bad storm roll through
jdodson
Sep 17, 2005
25
upper 40's on 119 is all i can get
upper 40's on 119 is all i can get at zip 22960. No trees in site,, i cant understand it. Any ideas
gpflepsen
3,305
316
SE NE
35 is good enough, as long as the signal is locked and green. I've had 34-36 for several years without issue.
gpflepsen
3,305
316
SE NE
How long has it stayed there? I'd give it at least 5-10 minutes. Did you do a switch check from the start?
gpflepsen
3,305
316
SE NE
But it will not work, comes up lost signal
If you cannot lock signal, then there's a problem. Is this a self-install? Check connections to make sure you have good ends and barrels. Are 110 and 129 OK with 119 only being problematic?
3HaloODST
6,648
97
Earth
What are your signal strengths on TPs 14, 15, 16, & 21 for 110/119? Are they both locked and green bar? Name acquired? No "wrong sat?"
What are your signal strengths on TPs 17, 18, & 21 for 129? Locked and green bar? Name acquired? No "wrong sat?"
Jim5506
8,440
4,087
Slaton, Texas
Have you confirmed that the center lnb is set on 119 by covering the outer two lnb's with aluminum foil?
You may be 10 degrees too far east.
3HaloODST
6,648
97
Earth
Yeah... In MENU - 6 - 1 - 3, are the sats listed in the following order?
119 110 129 ?
If so, then you are pointing at the right sats, may still have signal strength issues, may not.
If not, then you are picking up the wrong sats through the wrong LNBs.
All three are green?
Status says "Good?"
How about at MENU - 6 - 1 - 1 - Check Switch?
All green and "OK?"
Status "Reception Verified?"
Click on "Details" on the "Installation Summary" screen, do ports 1 thru 3 all say "Even, Odd?" Is port 1 119, port 2 110, and port 3 129?
Try clicking "Test" in the "Installation Summary" screen? Make sure "SuperDISH" and "Alternate" are not selected.
Fsn, Fx and Nat Geo
3 Sats with Legacy
