Need help with 6ft dish instal
wildboys
328
I am having a very hardtime installing my new fortec 6ft polar mount dish.I have install many motorized dishes without any problems but this one takes the cake.My zipcode is 72764.My long=94.1w lat=36.1n.I have the dish lineup with my true south which is telstar 5.My polar elevation is set to 36 measured with angle finder on the dish in the enclosed photos.I have a Chaparral Corotor II+ C/Ku Feed with lnb's.When i got everything assembled i pointed the dish towards G16 and checked all tp and got no picture on any tp's.I then slowly move the dish across the clarke's belt and could not get any pictures on my cband analog receiver.I then switched to my coolsat 5000 receiver to see if i had any signal.I had a signal of 94 and a quality signal of 7 on what i think is telstar 5 it is my true south and i have a motorized 1.2 meter dish so i know where to point the dish to get a signal.I first moved the whole mast very slowly to see if i would get a better quality reading on T5.The meter did not change so i raised and lowered the elevation but still no signal.I have double checked all my connections the plumbness of the pole changed lnb's but i cannot get a signal on any satellite.I am enclosing pictures of my install.If anyone see anthing i am doing wrong including my elevation settings please let me here your suggestions.
Focal length?
I've usually had good luck with pointing a CBand dish but maybe you could use the ole circular E* legacy LNB trick. Find a few strong birds, I'd shoot for 91W where there's linear KU and CBand. Then switch over to the C/KU rig.
First thing I would check is that the feedhorn is at the proper focal length. Then line up on your true south satellite, closest sat for your true south is g3 at 95 not IA 5. G3 is one degree off, which should work ok just means a little more tweaking. Set your proper elevation, then set declination. You should not have to touch elevation after that.
elevation=47.42
declination=5.17
azimuth=180.67
After you have set elevation/declination then rotate the whole mount on the pole until you get a signal, in very small increments. If your pole is plumb, and the elevation is set correctly you should be able to find it.
Unfortunately, there is no analog stuff full time on g3, so you will have to look for a DVB signal.
Good Luck
Doc
BTW, does this mount have an actuator? If you extend your actuator all the way and then set elevation, you wont be able to see east of your true south. I would extend the actuator just past half way for your location. Just make sure you dont "flop" the dish by going to far east ;)
digiblur said:
Focal length?
Type
Prime
Diameter
180 cm
Panels (sections)
6
Aperture Efficiency
70% min.
C – Band Gain @4.0 GHz
35.89 dB
KU – Band Gain @12.5 GHz
45.54 dB
F/D Ratio
0.38
Focus Length
682 mm
Material
Steel
Finish
Polyester Powder Coating
Color
Grey / Cool Grey
MOUNTING
Mounting Type
Ground Mount
Elevation Angle Range
0° - 90°
Azimuth
0° - 360°
Material
Steel
Finish
Color
Grey / Cool Grey
Pole Diameter Acceptable
75 mm
Net Weight
29.0 kg
ENVIRONMENT
Operational Winds
25 m / sec
Survival Winds
40 m / sec
Ambient Temperature
-40°C ~ +60°C
Relative Humidity
0 ~ 100 %
elevation=47.42
declination=5.17
azimuth=180.67
Good Luck
Doc
i am a little confused about the declination. where on the dish should i set it.36.177918 N, 94.104682 W is where i live.Should i still set elevation at 47.42 my zip is 72764.Should i set my elevation on the bar where the angle look up is setting on the attached picture or should i measure it on the top of the ring?
Once you set your main axis angle (Latitude) then use the declination screw until you hit the satellite arc. This is where a cheap satellite meter can be a great help. Then use a live transponder to fine tune.
Its looking good!
Its looking good!
Thanks pete i just hit g16 The declination was the problem.
Known Traxis 3500 AC-3 problem - will it ever be fixed?
