Need Remote Code for Samsung SIR-S300W
  • Server Issues.
    We are very aware that there have been system issues the past few days. In troubleshooting the system, it has been determined that the issue is at our provider and is hardware related. As of 12:05 PM ET our provider has moved us to a new server.
    Things seem to be running better on this new server. However in trying to diagnose the issue (before finding out it was a hardware issue) we made some system changes which we need to undo. So if you find any issues or errors please let us know in the Operations Center Forum.
    Thank you for your patience! Sorry for the issue!
Chasjonk
10
I have a Home Theater Master SL-8000 and have been unable to find the remote code for DirecTV's Samsung SIR-S300W receiver. Been going thru the 3 digit codes but none seem to work.
Can anyone out there help me out?
Auto Search Method
Use this method if none of the Set-Up Code numbers
worked for your device during the standard set-up proce-dure
or if the manufacturer or brand for your device is not
listed in Set-Up Code Tables.
1 Turn on the device you would like the remote control to
operate, either manually or with your original remote
control.
2 Press the corresponding Device Button (TV, VCR, SAT,
CBL, AUD, CD, DVD, or AUX) and the MUTE button,
simultaneously. SET will appear in the LCD.
Note: SET appears in the LCD for 20 seconds to indicate that
the remote control is ready to be programmed. The following
steps must be entered while SET appears in the LCD.
3 Point the remote control toward the device and press the
CHANNEL UP button on the remote control. Each but-ton
press sends the signal for one Set-Up Code number.
Keeping the CHANNEL UP button pressed produces a
quick scanning of the Set-Up Code numbers.
Release the CHANNEL UP button as soon as the device
turns off. Please confirm that you have the correct code
by pressing the MUTE button on the remote. You should
be able to turn your device on and off with this button.
If you pass the correct Set-Up Code number, you can
return to it by pressing the CHANNEL DOWN button,
one Set-Up Code number at a time, until your device
turns back on.
Note: During programming, the signal for POWER ON and
POWER OFF is located on the MUTE button. For devices that
use separate POWER ON and POWER OFF buttons, pressing
the MUTE button on the remote control during programming
will only turn the device OFF.
4 Once the correct code is confirmed, press the Device
Button to store the Set-Up Code number. PASS will
appear in the LCD.
5 Test the remote control for your device. Try the POWER,
CHANNEL UP AND DOWN, VOLUME UP AND DOWN
buttons, etc. If any of the buttons do not perform as they
should, please repeat the set-up from Step 1 using the
next Set-Up Code number for your device.
Note: Some audio/video devices have separate buttons for
POWER ON and POWER OFF. To operate these devices on
the remote, press the corresponding DEVICE Button to turn the
equipment ON and press the POWER button to turn the
equipment OFF.
6 Repeat the above steps to program the remote
control for each of your other devices.
You can recall the CODES if something happens:
Recalling the Set-Up Code Number
To display the three digit Set-Up Code number that was
stored for a device.
1 - Press the Device Button and the MUTE button, simultane-ously.
2 - Press the T/V button. The LCD will quickly flash the
three digit Set-Up Code number that was stored for your
device in that mode.
3 - Please write your Set-Up Code numbers in the chart
below, for future reference.
Hope this Helps!
