New Strange Problem
Carbon
11
So yesterday I installed a HR20 it replaced a old dual tuner tivo.
I installed a Sat C kit a couple of months ago.
The dish has been set-up for years and I have never had any trouble I usually get a signal between 85-100 on all transponders and all sats (101-110-119)
There is a total of 5 receivers total in my house.
1- HR20 Dual Tuner DVR.
1- Philips Dual Tuner Tivo.
3- Standard non DVR receivers.
On the dish there is a channel master SAM4402 multi switch seen here http://www.sadoun.com/Sat/Products/Channel-Master/6904IFD-Multi-Switch.htm
2 lines feed another multi switch in the basement that is a Perfect Vision PVMS-8EP seen here http://www.sadoun.com/Sat/Products/Perfect/PVMS-8EP.htm
then of course the lines go to the receivers.
Here is the problem when I put the HR20 on a HD channel the other receivers in the house lose some channels mostly the lower channels (4,5,9) locals.
I think that the Perfect Vision multi switch cant pass the correct voltage or the problem is with that multi switch any ideas guys?
I have tried to reset the HR20 something like 10 times now. I have tried resetting one of the others the problem still remains.
The HR20 won't work with that multiswitch. You must use the Zinwell WB68 switch.
10-250 broke, what will i get?
It's Only TV! (?)
