New subscriber: Can't watch HBO
$905.00
joshsquall
10
Just got my install done today. When I try to watch any of the premium channels on my living room TV I get a message that "Your TV does not support this program's content protection." It works fine on my other TVs. This setup worked fine on Dish Network + HBO. My receiver is an Onkyo HT-S6100 and the TV is a Samsung FPT-5084. Each of those should support HDCP. Any ideas?
Sounds like you are using component cables joshsquall. You have to use hdmi on hbo now.
You can still watch HBO using component cables. If you are getting that message it is because you are using HDMI and something is not HDCP compliant. Most likely if your HDMI feeds through an audio receiver then to the TV, you can take the receiver out of the loop and it will fix the problem (and run an audio cable to the receiver).
Last resort if it is your TV that is not HDCP complaint, you can switch to component cables.
Do I have it backwards then? I thought you had to use hdmi for HBO now.
Do you have any other devices connected (a second Tv, a DVD recorder, slingbox etc?)
I have an Onkyo TX-NR708 and I see that message for a split second while the digital switching takes a moment to kick in when changing modes. Maybe something is set wrong for Sat on your Onkyo or possibly you have a switching issue?
what is "HDCP compliant"
Picture Quality KVME Ch 20 LA
Trying to sign up for Directv... Is it always this hard?
