no audio..me tv
icu1954
275
lower alabama
does any one know why there is no audio on me tv? if there are some other audio pid i need to enter please let me know.:rolleyes:
Or a decent HD satellite receiver that plays all types of audio. Before you waste money on external add-on stuff, for nearly the same $$$ you can replace the receiver- possibly adding HD or s2 to your system also :)
A Sonic Voom its about 10-15 dlls, ten times less than an Openbox or other HD receivers.
I know you can get a Coolsat 8000 for under $100 but yeah that makes no sense. Sonic Voom/Cyberhome setup is a lot cheaper
Ok....you guys are right about the sonic Voom being cheaper, but I guess the point I was trying to make, was why buy adapters for sound, on a nearly outdated dvb-s only box, and still miss out on 90% of the good stuff up there. Makes no sense to me, but hey, to each his own.
Sent from my DROIDX using SatelliteGuys
I still use the Cyberhome decoder on my Visionsats, as it is necessary for much of my viewing. I have the Visionsats set up to record NASA-TV using the AC-3 audio, since it can be burned to a Blu-Ray layout directly without re-encoding (Blu-Ray and DVD specs do not support the use of MPEG audio). MeTV, ThisTV, and most (all?) of the PBS is also AC-3.
Of course, the Openbox is on HDMI, and decodes AC-3 internally, so its a moot point for that receiver.
AMC 15
It's a Long Way to the Top!
