No signal, bad LNB?
wecker20in
No signal at all. I don't have a multi line switch so can eliminate that. Checked the coax cables w/ the Fluke and no resistance there. Tried adjusting the dish and got nothing. Anyway of testing the LNB w/o special tools? The only thing it could be is the LNB or the reciever at this point. Unless there's a problem on DTV's end but I doubt it. Weather is nice and sunny.
It's not Direct mine is running fine at the moment.
It probably is the LNB, but did you check to see if there is voltage at the lnb?
there should be 13, or 18V if there isn't the the ird is bad, or there was a short, and it needs reset. The reciever needs to power the LNB if it doesn't you will get nothing.
"No resistance" is a short.:)
But you probably know what you meant if you have a Fluke!
Future of 3 LNB
Marginal Start from DTV...
