Noise on E! and other SDs...
D
dtsfanohio
Thread Starter
170
I assume this is a known issue ?? but I see noise on E!, CNN and other SDs..especially on the reds... My stb is set at 1080i.Others see this? Is this being looked at ? Thanks
Pete In Plano
Pete In Plano
211
Comedy is really bad tonite.
G
GabeNet
59
Yeah, I'vseen it too on Spike and Comedy. I agree that it is mostly in the reds.
E
eddiew
36
Yes, Im seeing the same. Also the picture is not as sharp as DTV. I have both at the present time. All SD is better on DTV..(much sharper).
C
cameron119
288
Typical C-band LNB artifacts from a faulty/dying LNB. Could also be noise from analog transport on their end.
S
StingyScotsman
StingyScotsman
61
Me 2
I've noticed this since day 1. High Luma colors break up on certain channels. (I've noticed it on E! and Comedy Central.)
L
Lem52
249
Cookeville, TN
Whats strange is why in the heck don't they fix it? Don't they know that don't look good coming from their end?
Lem52
P
pOiNTBLaNK
162
This has been a known issue. Encoder upgrades are currently being processed.
C
cameron119
288
The noise we are speaking of is analog in nature. I don't know how the hell an encoder upgrade will fix that.
Any cable system that has this type of noise is experiencing an issue with the LNB on their dish that receives their feeds. The digital encoding is as clean as a whistle. You can't polish a turd (dirty analog feed), however.
P
pOiNTBLaNK
162
This has been addressed before. It has nothing to do with a faulty LNB. If it was that simple it would've been replaced a long time ago. The problems that you are seeing are due to the current encoder not working properely. Once new encoder comes into play as well as the MPEG4 & WM9 upgrades those problems will be long gone.
E
eschu97611
573
L.A. CA
Oh brother! The old "encoder" excuse again-I think Rome was built in a shorter amount of time-and I don't mean Jim either-he he he
D
dtsfanohio
Thread Starter
170
The noise seems better (less) tonight... anyone else think so?
C
cameron119
288
Listen guy:
No encoder can inject "sparkles" like that. Anyone who knows analog video transport (not you) knows that the typical cause of that is a faulty C-band LNB at the downlink. This noise is common on UNENCODED sources as well. Now, Mr. Wizard, is there an invisible encoder in play? The encoder takes the source material and compresses/encodes. It doesn't have the capability to randomly add sparkles that are conveniently reminiscent of faulty C-band equipment.
Further, if this is an issue with all the encoders, why aren't these artifacts on every SD channel? Why aren't any of the HD channels affected? I'll tell you why: all the HD's and some of the SD's are received digitally, not via C-band analog.
Some folks don't take the time to read any of the posts. I suppose Pointblank is a bot designed to pop-up and say "encoder issues, Microsoft's WM9 will cancel-out a faulty c-band LNB and analog noise".
E
eddiew
36
What about the sharpness issue? Take a look at letters on the SD channels , maybe the end credits of a movie. There is a ringing of some sort , almost out of focus. Even overcompressed DTV looks better.
O
occammd
397
I have had this since VOOm was installed a month ago on ABC family and Nickelodeon mostly.
DarrellP
DarrellP
I Think, therefore, I am.
4,298
Salem, OR
I've never had D* but I can tell you that Voom SD is far better than E*. The letters are much sharper and though some ringing is noticeable on some channels, it's not true for all channels, at least with my display.
C
cameron119
288
I've had success with Composite and S-Video. With component, the colors seemed to "ring" and have no real boundaries. It was like a psychedelic picture show (okay, not that bad).
G
GadgetRick
394
Near NYC
Dtv?
I do have DTV and I can tell you Voom's non-HD looks a LOT better...sparklies and all...
The Rickster
E
eddiew
36
GadgetRick, what channels are you comparing? I see just the opposite. Voom much worse than DTV. Definitely softer on Voom.
D
dtsfanohio
Thread Starter
170
I had the installer back today and he installed the VoOm dish/LNB rather than use the DirecTV dish/LNBs .... and my noise is essentially non-existent now on the SDs.
Similar threads
L
Replies
5
Views
1K
jgantert
jgantert
B
Replies
Views
1K
Karl City of Angels
K
jnardone
Replies
Views
1K
Sean Mota
S
M
Replies
Views
820
ram1220
R
DarrellP
Replies
4
Views
2K
squicken
squicken
