NOS HTS Actuator
Captain Midnight
634
432
Greers Ferry, Arkansas
I just bought this and it is in transit. $10 +shipping was enough for me to chance it being untested. It looks new. Anyone know what company HTS sourced actuators from? Or perhaps they made their own?
Reactions: Brct203 and FTA4PA
Looks like an original manufacturer Super Jack. Hopefully it's a reed switch model. Get a photo of the inside motor assembly, and we can likely tell for sure with that.
Reactions: FTA4PA
This thing tested out ok.
But...I have a problem now.
I started to smell a little bit of that "motor smell" and took it off... Well I had never done that before. I reassembled it the way I thought it was. And this is the result. These magnets are pretty well crushed. Is there any hope for repair? I feel like a huge idiot.
  • Sad
Reactions: FTA4PA
Yes you do have a problem. BTW those are not magnets, they are the motor brushes that pass electrical current to the spinning armature.
Wow, sorry to hear that. :( If you go to Amazon or eBay and search for the term 'motor brushes' you will get a ton of results. You may be able to find something that looks like the originals that will work for you. Worth a try anyway. :)
Older electrical shops carry motor brushes. If you can find one of those. Or, search Ebay, Amazon, or just Google for "motor brushes". Better yet, contact Venture, send them a photo, and ask them if they have brushes that will work. IF that's a Venture actuator, they might be able to supply them. Venture Mfg Co Contact Us Today!
Thanks for the info. I didn't mean to go silent for so long but I was pretty bummed at myself for a case of "curiosity killed the actuator"... I just put it aside and totally put the thing out of my mind after the accident.
My tax return was very good this year, so I am thinking about a new actuator. I have a 10ft mesh dish and want 36" because I can see from 22w to 133w at my location. I can only get 40w-133w with my old 24" and the actuator hates me when I need to pull back east if I go west of 125w.
So is the ball screw really worth more? I might also have a lead on a 12ft mesh that may be put into service soon, if that helps for a recommendation.
Make SURE your 10' dish can handle a 36" actuator, without Flopping, Many older kinds of them can't, because the polar mounts aren't balanced quite right.
Yes, the ball-screw actuator likely will never wear out in your lifetime. Though it's very much over-kill, unless you have a very heavy dish, such as a huge Fiberglas dish. Or, you live in an area with a very high average wind speed, and need more strength to hold your dish.
My actuator was a 36" Digiwave. Both brushes were gone and one magnet came off. I checked Amazon and could not find the same brushes but close. I bought some brushes a little bit bigger and sanded them down to what I needed. I had to reuse the old springs because the ones that came with the new brushes were wider. I also reuse the old brushes wire with the connector because the new ones were different. I just cut both wires ( new and old) half way and soldered them. I also sanded the motor wall inside and glued the magnet back with two types of Cyanoacrylate: mid to be able to position it properly before it got stuck and then aded thin on the borders with a catalyzer. Let it dry for two days before assembling it back. Since I had to dissassemble the full actuator, I added new grease to the gear and lubricate every posibble part, plus remove all dust a repainted. It is working like new. My point is, don't be afraid to try to fix it. If everything else is OK, replacing the brushes is not a big deal. Just be carefull when inserting the rotor back to push the brushes away. You can use a small wood stick to push them apart.
Reactions: FTA4PA
Solid 6' Vs. Mesh 8' BUD
AJAK Polar Mount and Reed Switch
