OTA issues....
cruzmisl
114
I've been frustrated recently by the OTA performance of my Voom box. One hour I get all HD locals and the next hour I get "signal unavailable" on 3 or 4 channels. The next day they are back. The antenna is in my attic and doesn't move. Any ideas on how to fix this problem?
Thanks,
J.
It could be a number of things:
1 - How far are you from the towers?
2 - Are the channels transmitting at full strength?
3 - Are you using a diplexer?
1. Maybe 15 miles max.
2. Yes, the strength on most is typically >90
3. Yes I am since there is no input for the antenna directly into the Voom box.
Any other suggestions??
There is an input for the antenna on the Voom box, but it requires you to remove the diplexor on the Voom box itself. I believe you can remove both diplexors if you can run a cable each for the antenna and for the satellite.
However, with only 15 miles from the antennas, and if the Voom box is reporting local signal strength on at over 90 (even when you have no picture) then I'm not sure what the problem is.
I have had a similar problem with some stations in my area when some of the digital locals occasionally go off-air -- signal strength of 0 -- and then pop back on full strength the next day. (I wonder if they doing some sort of maintenance?)
CDH.
Thanks,
J.
For what's it's worth, I've had 4 HDTV receivers, and they all work well with different channels, "Samsung 351,Zenith 520, Toshiba Ds3000, and Voom ",it's most likely not a problem with your Reciver but with the power a Single provider transmit at, and the threshold of anygiven receiver, " voom " work's best of the one's I've had, 2nd Zenith, worst Samsung, I still have the Zenith seems in our area ABC & Fox have the most problems PBS ??, Until all providers start transmiting at full power it's just a rat we have to eat.?.
DB 8 ota
I've been getting a weird result...
