PCI DVB-S cards and HD
When I had Twinhan Data and the Digital TV program I had many problems.
I would recommend if your not using your Twinhan card for internet to uninstall the Data program, then uninstall the Digital TV program and reinstall only the Digital TV program.
Otherwise you have to disable the Data program and disable the device (DTVNet Ethernet Controller) in the device manager if you want to use the Twinhan for FTA TV.
@ Mixe
Thanks for your concerned but im using dvb dream and pc dvb before on my SS2 and works fine . It so happened when i changed my dvb card to twinhan vision 102g that arises my problem .
@ qwert1515
Sir , I noticed that i can only get green signals if i connect the cable to the LNB OUT , is this normal ? . Thanks again ill try to use one program only .
@ qwert1515
Sir , bulls eye my twinhan dvb card works ok , got it at last i just installed one s/w DIGITAL TV 3.3 . Thanks for your advice . On my dvb dream i select BDA satellite device and got all channels.
Why wont 18 inch dish work for FTA?
Buy a cheapo Lnb?
