quaility signal flucuates
Joe G.
12
Peoria, AZ 85383
I am getting a signal of 90% and my quaility signal flucuates between 45%- 73% . I have checked all my connections- everything is good. I am usinga DISCqE switch before the motor between the lnb and motor. Do I need to install a multi-switch???
Does this happen on a specific satellite / transponder or on all? Does it happen with a direct connection from the receiver to the LNB?
Anyway to avoid stacking two switches and use a single switch after the motor? The multiple switches plus the motor pass-through loss totals approximately 8.5dB loss.
Usually a fluctuating signal quality reading is related to dish alignment or feedhorn skew/placement. Just not getting enough good signal to properly decode without errors.
Bones of the forest
Where to buy an aluminium satellite dish?
