Question
topoli
Feb 11, 2007
7
Hi
I have 2 Ariza 700 .
One works extremely fine but the second box keeps freezing channels and shuts off automatically and keeps doing this reboot.
Is there any thing I should do with your help
Thanx in advance
What channels are causing the reboot? I had a pansat that would do something similar when I hit a channels with AC-3 audio
thanx for respond .
Actually i think i sort of found out what is happening.
using 2 receiver of the same kind on the same LNB that has 2 outlet was the problem because both receivers are trying to use the lnb and one jumps the other one off because they carry the same interface .
I replaced one of the receivers with another brand and those 2 work no problem from the same LNB.
what is left to check is to put up this receiver with another dish pointing on another satellite to see if it will work without freezing if it didn't then I was wrong from the beginning.
Xtreme and Xtreme ll LNBF
Blind scans that stick
