SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 04/07/2007
$905.00
Not really, at least you CAN watch NESN in SD until then if you are in that market or you subscribe to MultiSports....
YES fans are simply shut out. Period.
Once again, full disclosure.... To this Mets fan, my not having to give Steinbrenner $2 a month is a PLUS in my book.....
Here we go. Looks like MORE HD RSN's are available.
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 04/07/2007 - 41 changes
Uplink Comparison Range: 04/03/2007 07:35P - 04/04/2007 12:47P - (GMT-06:00) Central Time (US & Canada)
141 - ESPNA (A) removed from EchoStar7 119W TP 18 ConUS beam
147 - ESPNA (A) removed from EchoStar7 119W TP 10 ConUS beam
231 - RFDTV - EchoStar8 110W TP 19 ConUS beam changed flags from 0101027F00FCFF to 0101025A00FCFF
281 - ANIML EchoStar7 119W TP 02 ConUS beam changed to BOOM - EchoStar8 110W TP 15 ConUS beam (A)
282 - ION EchoStar7 119W TP 14 ConUS beam changed to DHLTH - EchoStar7 119W TP 17 ConUS beam (A)
283 - TDIS EchoStar7 119W TP 06 ConUS beam changed to CSTV - EchoStar8 110W TP 05 ConUS beam (A)
284 - HLMRK [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Not Available
285 - MUN2 [MPEG2 SD] - EchoStar8 110W TP 09 ConUS beam changed to Not Available
286 - REAL [MPEG2 SD] - EchoStar8 110W TP 05 ConUS beam changed to Not Available
289 - FREE (A) removed from EchoStar8 110W TP 02 ConUS beam
290 - HBO-E [MPEG2 SD] added to EchoStar7 119W TP 02 ConUS beam (Not Available)
291 - HBO2E [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Not Available)
292 - HBOSG [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Not Available)
293 - HBO-W [MPEG2 SD] added to EchoStar7 119W TP 19 ConUS beam (Not Available)
294 - HBO2W [MPEG2 SD] added to EchoStar7 119W TP 13 ConUS beam (Not Available)
295 - HBOFM [MPEG2 SD] added to EchoStar7 119W TP 08 ConUS beam (Not Available)
296 - HBOCY [MPEG2 SD] added to EchoStar8 110W TP 11 ConUS beam (Not Available)
297 - HBOLT [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (Not Available)
298 - FREE [MPEG2 SD] added to EchoStar8 110W TP 02 ConUS beam (Available)
361 - PRIME [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
366 - FOXSW [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
367 - FOXW [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
370 - FOXS [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
373 - FOXFL [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
997 - FPCHN (A) removed from EchoStar1 148W TP 29 ConUS beam
997 - FPCHN (A) removed from EchoStar3 61.5W TP 31 ConUS beam
998 - FPCHN (A) removed from EchoStar1 148W TP 27 ConUS beam
998 - FPCHN (A) removed from EchoStar3 61.5W TP 18 ConUS beam
5748 - TWCV2 [MPEG2 SD] added to EchoStar1 148W TP 23 ConUS beam (Available)
5895 - RFDTV [MPEG2 SD] added to EchoStar8 110W TP 19 ConUS beam (Not Available)
5897 - DRMT1 [MPEG2 SD] added to EchoStar8 110W TP 21 ConUS beam (Not Available)
5898 - DRMT2 [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Not Available)
5899 - DRMT3 [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (Not Available)
5900 - DRMT4 [MPEG2 SD] added to EchoStar8 110W TP 08 ConUS beam (Not Available)
5901 - DRMT5 [MPEG2 SD] added to EchoStar8 110W TP 16 ConUS beam (Not Available)
5902 - DRMT6 [MPEG2 SD] added to EchoStar8 110W TP 06 ConUS beam (Not Available)
7020 - KPXJ [MPEG2 SD] - EchoStar10 110W TP 18 Spotbeam 15(LA,AR) changed to Available
9408 - STARF [MPEG2 SD] added to EchoStar5 129W TP 17 ConUS beam (Not Available)
9408 - STARF [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (Not Available)
9417 - EDUCA [MPEG2 SD] added to EchoStar5 129W TP 17 ConUS beam (Not Available)
9417 - EDUCA [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (Not Available)
Channels in the system: 3248
(A) = Available to subscribers
(NA) = Not Available
Err. So If you are in the right area, do these just light up? Also What are all the names for each of the RSN's and what is the EDUCA channel? Is that not in HD range? I still want to see INHD!!! It's great they lit up the RSN's for all of those waiting on them... but do they have plans to light up any national HD soon? Cinemax HD for example? :(
-B
" Is that not in HD range?" - ask digiblure to implement decoding Service Type byte ;)
9408 & 9417 are the PI area
Will do.. what about how to get these RSN's.... Should these come on automatically based on region? I used to have one sports net a long time ago but forget how that came about. Do i need to sign up for them on a one by one basis or get the multi sports package or something to see them all (if that package even exists these days still)?
-B
So I am in the LA region for example. I have platinum Hd, networks, supers, u name it.. yada yada yada... should i get this automatically then when they do actually come on? I am normally not that mad into sports but hey if it's HD I will watch it!!! ;0
-B
Now I want to know what FOX RM will have as far as programming. As far as I know they lost all of their pro-sports contracts to Altitude. Is there any national HD programming on the FSN's?
yes as long as you can see 129 satellite
FYI... I edited Scott's post with the new format we are using.
I'll send Scott the new version when I put the last touches on it ;)
Just need FSN Houston now, and I'm covered for the Astros, Rangers and Cardinals in HD on their RSNs. Then I just need for the Royals to come into the 21st century and start showing RSN games in HD.
How to stop recording from starting?
HD not always HD
