SG-2100
stecle
380
220
Between the North and South Pole
I have a Manhattan RS-1933 with a SG-2100. I decided to update the software with the latest version on the Manhattan website. I loaded the software on the Manhattan and I then noticed that I was not getting any signal. I looked out the window and my dish was pointed to the ground as far West as it could go. WTF?
Anyway I tried to move the dish with the Manhattan and it would not budge. I went out to the dish and noticed that I have a green led lit on the motor. I tried manually moving the dish with the buttons but nothing happens. I tried the reset button and still nothing.
I would sincerely appreciate any suggestions.
Steve
If you are set up with USALS to run your motor, check to make sure your coordinates didn't get wiped with the new firmware load. That's what happens with the MicroHD receiver, and we have to re-input them each time we upgrade.
It's also possible that some "soft limits" for the motor got set in the receiver. If it has a menu item to clear them, then clear them and see if it moves.
Also check to make sure that your USALS coordinates are Longitude (W) and Latitude (N).
See if the dish moves back to '0' (true South) when you go into motor options and select 'Goto Reference'.
Best way to power an LNB?
Whatever Happened to....Dee Ann & her Big Dishes?
