I thought my dish or mount had somehow shifted, because I was no longer receiving any satellite east of 53W. Nope
Turns out the motor is somehow limiting itself to about 51W. There are no enabled limits on the STBs (I tried 3 different ones), but each time it reaches that point, the LED on the motor turns red. It will move anywhere west of there, but refuses to go east. I'm even more concerned because I tried to do the reset sequence (unhook the coaxial to the STB, press both buttons simultaneously, then reconnect the coaxial; release after five seconds of restoring power). The result was nothing. No reset at all (usually this procedure drives the motor to the "0" position and clears any weird thing in its memory). Fortunately, I don't watch much past 53W, but I would have like to have tried for 30W once the leaves fall off this winter ... plus I'm worried about a total freeze-up with no reset. I'm not so mechanically inclined -- I read where one member discovered a damaged spring inside the motor.
Recommendations? New motor (*whine*)? I heard the one I had was pretty good, but is there something better out there with USALS?
