SiriusXM S-band Reception
Old2New
The question is, "how is it possible to receive SiriusXM radio S-band geosynchronous satellite signal without dish and LNB"? Apparently, SiriusXM receivers utilize short wire omnidirectional antenna, and it seems S-band signal strength would be inadequate.
The SiriusXM marketing info says their receivers combine three separate signals, two identical S-band signals from neighboring satellites but with one delayed by 4 seconds from the other, and a third signal from terrestrial repeaters that are fed by a separate Ku-band satellite (AMC-6), received by Ku-band dishes, and rebroadcast locally across N America.
The Wikipedia "Sirius Satellite Radio" article, perhaps written by SiriusXM marketing, mentions a complex chip set of up to six ASICs.
My suspicion is this is largely BS, and all the SiriusXM receivers are only receiving the terrestrial repeater broadcast.
SiriusXM has repeaters only in some of the larger metropolitan areas. There are entire regions that aren't covered. Here's an older map (2010?):
SiriusXM has reportedly shut down more than a few (if not all) of these repeaters since 2010.
They obviously can't be serving Bozeman or Peoria from a repeater. More than a few of the repeaters were located in tunnels and existed only to serve the interior of those tunnels.
If they can draw five or more GPS satellites into a wristwatch, they can certainly grab a couple with a much larger SARS antenna.
SiriusXM operates in a relatively low frequency band (S-band) that is 1.97-2.69GHz which gives it pretty bulletproof atmospheric penetration in addition to the entire satellite platform (SSL-1300S) powering only one transponder. This frequency band is not far above that of GPS that runs around 1.2-1.6GHz.
Don't let the fact that you can't get your head around something lead you to believe that it can't possibly be happening.
Thank you. The explanation that the entire SSL-1300 platform power of ~10KW is powering only a single transponder answers my question.
By the way, the Ku-band repeaters are only on the Sirius side of SiriusXM. The XM side's repeaters takes the strongest signals from the main S-band satellites and rebroadcasts them on the terrestrial band.
The XM side of SiriusXM is better in just about every way. The one thing that made the Sirius side better was the use of satellites in high-altitude polar orbits which made the need for repeaters on Sirius way much less than what was required for consistent reception on the XM side.
Now, of course, those Sirius polar satellites have been shut down for years, crippling the Sirius side since it has so many fewer repeaters than the XM side and SiriusXM is chomping at the bit to shut down the Sirius side.
On the XM side, each satellite powers two transponders: one is aimed primarily at the East, the other at the West. The Western satellite does the same. That makes a total of four transponders serving the continent.
As for your comment about SiriusXM marketing posting about ASICs on Wikipedia, there are two receivers per each of three bands on an XM (not Sirius) radio for a total of six receivers on the three bands. The Sirius receivers only have three receivers. It's a subtle feature that makes the XM receivers so much better at receiving reliable signals.
Howard Stern
