SiriusXM S-band Reception
Old2New
The question is, "how is it possible to receive SiriusXM radio S-band geosynchronous satellite signal without dish and LNB"? Apparently, SiriusXM receivers utilize short wire omnidirectional antenna, and it seems S-band signal strength would be inadequate.
The SiriusXM marketing info says their receivers combine three separate signals, two identical S-band signals from neighboring satellites but with one delayed by 4 seconds from the other, and a third signal from terrestrial repeaters that are fed by a separate Ku-band satellite (AMC-6), received by Ku-band dishes, and rebroadcast locally across N America.
The Wikipedia "Sirius Satellite Radio" article, perhaps written by SiriusXM marketing, mentions a complex chip set of up to six ASICs.
My suspicion is this is largely BS, and all the SiriusXM receivers are only receiving the terrestrial repeater broadcast.
SiriusXM has repeaters only in some of the larger metropolitan areas. There are entire regions that aren't covered. Here's an older map (2010?):
SiriusXM has reportedly shut down more than a few (if not all) of these repeaters since 2010.
They obviously can't be serving Bozeman or Peoria from a repeater. More than a few of the repeaters were located in tunnels and existed only to serve the interior of those tunnels.
If they can draw five or more GPS satellites into a wristwatch, they can certainly grab a couple with a much larger SARS antenna.
SiriusXM operates in a relatively low frequency band (S-band) that is 1.97-2.69GHz which gives it pretty bulletproof atmospheric penetration in addition to the entire satellite platform (SSL-1300S) powering only one transponder. This frequency band is not far above that of GPS that runs around 1.2-1.6GHz.
Don't let the fact that you can't get your head around something lead you to believe that it can't possibly be happening.
Thank you. The explanation that the entire SSL-1300 platform power of ~10KW is powering only a single transponder answers my question.
SXM still giving discounts
Users Who Are Viewing This Thread (Total: 4, Members: 0, Guests: 4)
