Slimline 3 and H25 issues
CREWofMAROON
16
4
Just bought a Slimline 3 satellite for tailgating and will be using my neighbors H25 box as we tailgate almost everyweekend. I am getting 771a error and it says no SWM found and says I need a power inserter. Completely clueless. I have correctly setup the azimuth tilt and elevation but nothing.
The H25 ONLY works with a SWM setup
The LNB has to have only one connection and you need the power inserter. If the LNB has 4 outputs thats the wrong setup and the H25 wont work with it
Great. What model numbers will work, he also has the big box. Not sure on model number.
Iceberg. Could you maybe send me a drawing of how it should be hooked up. Thanks. Also the BBC connectors can those be picked up locally.
Can someone draw a simple diagram of using the Slimline 3 and HR24/100 reciever, thanks. Also need to know where I can get my hands on 2 BBC adapters ASAP.
CREWofMAROON, you really only need one bbc and one line connected if you are going to watch one channel and don't care about recording another one at the same time.
Raoul, can this still be done with out BBC if I were to watch non-HD channels? Only asking if I am unable to get a BBC before Friday when I head out to tailgate.
I was able to hit Satellite 101 with high 90's last night, but I was unable to continue after that, it would stay 0% when trying to update guide.
Yes, the bbcs are used to get signals from the hd satellites at 99 and 103, so without it you should be able to get sd channels. Are you sure you have a Slimline 3 and not a 5? How many pods are on it?
Oh yeah! It's a 3 all right! Were you able to get any channels even though there was no guide info?
I could never exit from the guide update it would stay at 0% and not let me go anywhere from there and/or could never exit the setup menu's.
You would have to set the satellite setup to 18" round to get past that issue
menu
settings
system setup
scroll down to satellite
then repeat satellite setup
menu
settings
system setup
Iceberg you are the man, thank you sir!
DIRECTV CINEMA
Question for folks in Atlanta
