sonicview, 8000hd, editing, channels
hans
15
Hi
I am trying to edit channels from AMC 1 . Cannot delete any channel. I went to factory reset and that only deleted Channels from another satellite I had, but did nothing to change the channels that are in the AMC 1 .
I want to clear the list and install a new updated channel list. I tried to install the list from Update I cannot install it using the USB stick, nor using the null cable.
I appreciate if someone could help me .
I would unplug the unit and then do a factory reset again that should blank out all chans.
Thanks,I tried that, but no success. When I select the factory reset it comes up with bar that has a key and four - - - - That is what I get. No change in the channels. So I know not what is going on. May be some body does.
Thank you very much four zeros did it. Would you be able to help me to get the new update satellite & channel list installed on the sv8000hd. Check original post.
thank you.
Primestar dishes for cband
Can I pick up vertical signals with 36" directv internation dish?
