starchoice lnb question
domando1069
54
7
Hi all
I have a starchoice lnb that looks like a pop can. It is about 2" round and 9" long. I attached it to a scalar ring and mounted it to my 10' BUD. I set my meter for Galaxy 10R. I could not pick up a signal. I tried AMC4 same thing, no lock. Is a starchoice lnb different then a ordinary 10.750 linear lnb? The scalar ring had a removeble c-band lnb, so I just wrapped electrical tape around the lnb until it fit tightly into the hole on the scalar ring. I also tried turning the lnb 90 degrees and no luck.
The LNB is what we called Stacked where it "stacks" the H poalrityy stuff above the V.
When you aim the dish, make sure to select a V transponder.
LNB LO is 10750
Speed-HD on Starchoice Guide yet?
BEV Subscriber in Southern California
