Stargate Atlantis
Just bought it from Amazon for $11 and some change. Too bad they didn't do a multi-disc set and put a lot more episodes into it. There are so many that were really terrific, not just those two... Just off the top of my head, I can think of at least a dozen that were really good...
Scifi Version(5 Commercials edited out)
Complete name : L:\SGA McKay & Mrs Miller.ts
Format : MPEG-TS
File size : 3.24 GiB
Duration : 43mn 21s
Overall bit rate : 10.7 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 43mn 21s
Bit rate mode : Variable
Bit rate : 9 574 Kbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.154
Stream size : 2.90 GiB (89%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Duration : 43mn 21s
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Stream size : 119 MiB (4%)
Language : English
Syfy Version (5 commercials edited out)
General
Complete name : L:\Syfy\SGA\SGA McKay & Mrs Miller.ts
Format : MPEG-TS
File size : 3.16 GiB
Duration : 43mn 22s
Overall bit rate : 10.4 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Duration : 43mn 22s
Bit rate : 9 315 Kbps
Maximum bit rate : 16.1 Mbps
Resolution : 8 bits
Colorimetry : 4:2:0
Bits/(Pixel*Frame) : 0.150
Stream size : 2.82 GiB (89%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Duration : 43mn 22s
Bit rate : 384 Kbps
Language : English
Recorded with Hauppauge, edited with VideoRedo... (used media info for the stats) my WDTV showed the Syfy version as stated... 41 minutes and some change...
The Last Kingdom
‘Sherlock’ Returns To BBC In Series’ Most-Watched Episode Ever
Users Who Are Viewing This Thread (Total: 4, Members: 0, Guests: 4)
