STREAMING video from the AZBox to your PC
How to stream video from the AZBox to your PC via WiFi connection
This procedure is only applicable for streaming the received satellite signal and does not provide a means for streaming any of the files on your HDD (including programs that you have previously recorded from the satellite).
There are two operational steps involved here.
1]  Starting the streaming broadcast from the AZBox.
2]  Starting the streaming reception on your PC
1]  STARTING THE STREAMING BROADCAST FROM THE AZBOX
In the TV mode (viewing a satellite channel) press the MENU button on the remote.  Scroll down the list of options to highlight STREAMING and press OK.  You will now be prompted to enter an IP address, a PORT number and a time DURATION for the broadcast.
IP address:  Enter the IP address of your PC
PORT:  Enter 9000
DURATION:  Select NOT DEFINE for continuous streaming with no time to end.
Note:  You may select any duration from 1 minute to 24 hours here if desired.
After these entries have been made, scroll down to highlight START and press OK.
An LED on your AZBox will illuminate and the streaming broadcast should be in process.  (On the Premium Plus, the RED LED will turn on.)
2]  STARTING THE STREAMING RECEPTION ON YOUR PC
You will need the application file VLC MEDIA PLAYER installed on your PC.  There are differences in how the versions of VLC operate, so you will have to adjust your setup in this process to compensate for these differences.  Tested versions of VLC here were 1.0.5 and 1.1.5.  We will discuss how to modify your steps for each version.
VLC VERSION 1.0.5
Open your VLC application program and in the media player's toolbar, select MEDIA.  From the drop-down list, select OPEN NETWORK STREAM.  The new page that opens will set up the media stream selections.
If you have an older version of VLC, such as this (1.0.5), you will see a box for entering the protocol language for the streaming technique.  If you click on the drop down arrow, you will see the selections.  Locate, highlight and select the UDP (User Datagram Protocol) option.
You will then be prompted to enter an IP address in the next box.  Here, you can enter either your computer's IP address or the universal streaming address which is 224.1.1.100
The next box to the right of the IP address entry requires a port address to be entered.  Enter 9000 for this selection.
Quickie example shown below.
[PROTOCOL]  [IP ADDRESS]  [PORT]
i.e. [UDP] [192.168.1.101] [9000]
After these boxes have been filled out, you can then navigate to and click on the PLAY button at the bottom of the screen and the streaming video should begin.
VLC 1.1.5 VERSION
In the more recent, updated versions of VLC, such as 1.1.5, you will
not be prompted for or allowed to select the UDP protocol, but it is still required.  The UDP protocol and the selected port number will now be required to be entered all in one string, in one box.  It is assumed that you understand the background information and know how to enter the string appropriately.
Open your VLC media player application.  Click on MEDIA and from the drop down menu, select  OPEN NETWORK STREAM, just like you do with the other versions.
The display will be entirely different and there isn't any specific or dedicated boxes to enter your information in. There is only one box that prompts you to enter a network URL.
In this box, you must enter the protocol type, IP address and the port number in its entirety as a whole address, examples shown below:
udp://@(my pc's IP address):9000  Example:  udp://@198.162.1.101:9000
or
udp://@224.1.1.100:9000
You can take the entire address just above, udp://@224.1.1.100:9000, copy and paste it into your VLC's address bar and then click on PLAY and it will open the stream right off.  If you type it in manually, remember to include the "@" symbol in the address when using this version of VLC.
This information should get you to the basics required.  You will have to adapt to any variations that may present themselves within your own system, but we will follow up with more information here as it presents itself.
Keep looking up!
RADAR
