superdish 121 pole mount
Hi all,
Just wondering if this is a option? Can I use a tripod on the peak of my roof with maybe 10-15ft pole? I would run some support cables from the pole.
If this would work, were would I get a tripod that holds 2in od pole from? Local Hardware store, Radio Shack, RV store, Ect...?
Looking for options rignt now to clear a tree at 105.
Thanks,
BigJohn2
John, no where to put the Diush on a pole on the ground?? I've seen dishes on tripods that high on the roof, but I sure would'nt want to be the one to install it or have to service it. The Superdish is a huge wind catch and aiming it on a 10 or 15 foot pole would definitely be a challenge.
Ok, how about this. Install the Superdish were my Dish500 is to get 110 and 119 then take the Dish500 and put on a tripod and use it for 105?
Much smaller dish then the superdish and a lot lighter.
Thanks,
BigJohn2
Got the superdish today and a 625. I'm getting 75 signal on 105.
Thanks,
BigJohn2
No way. For two reasons.
  • The 105 LNB is FSS, not BSS like 110/119/61.5/148/129.
  • FSS birds like 105 & 121 need the bigger reflector - for two reasons. Focus & gain.
75 on 105 sounds decent. Of course, it depends on the transponder. But if you're getting your channels with a 75 signal, you're good to go.
Thanks,
BigJohn2
Sounds like you are all setup. Simon is right about the 105 issue on both topics, a smaller dish will not work and 75 is a good signal. You use to not be able to get over 55 when they first came out.
Ok, what transponders should I look at on all three?
Thanks for all the help and info. I have learned a lot in the last week when I first found this site.
later,
BigJohn2
Well, it's 11 & 12 for 110 & 119. I don't remember the others offhand.
You can go to http://www.dishchannelchart.com and find your locals transponder.
OR, most single-tuner receivers Signal screen will automatically show the satellite & transponder of the last viewed channel. You can verify this by selecting, say, 119-17, exiting, tuning to a local, then go back to the signal screen and see if it switched to the 105 satellite.
Thanks, I found my local on 105 from that website. They are on tp23.
Later,
BigJohn2
What is the % of market that HAS to rely on Dish for Locals ?
A couple of questions concerning VOOM
