Tailgater First Impression
j6harri
39
Rogers, AR
All,
I received my Tailgater today from Claude and wanted to post some information for those interested.
Attached are the pictures from the un-boxing and initial setup.
Setup was as easy as you can imagine. Put the tailgater on a level surface with a clear view of the south. Connect the included 50' coax cable to the Tailgater and your 211K receiver running software version L499 or higher. Plug your receiver into the wall and wait a couple of minutes.
The first screen you see is the Portable Antenna Setup Screen. Simply choose your state and select scan. Then you will see the switch installation check, acquiring signal, and downloading program guide screens.
Once these are complete, about 10 minutes, then you are watching TV.
I did some quick test ESPN, ESPN2 no issues. Changing channels takes about 5 seconds. I then tuned into my locals. Complete Signal Loss 015 Error. WHAT???
I then check my locals in SD and they are fine. So I decided to get some readings to compare the Tailgater with my main dish.
Tailgater
Sat - Trans - Signal - Channel
129 - 03 - 5 - Locals HD
110 - 23 - 55 - Locals SD
110 - 07 - 33 - ESPNHD
129 - 30 - 31 - ESPN2HD
119 - 13 - 25 - USA
1000.4
129 - 03 - 21 - Locals HD
110 - 23 - 66 - Locals SD
110 - 07 - 64 - ESPNHD
129 - 30 - 53 - ESPN2HD
119 - 13 - 76 - USA
My Zip Code is 72751
Obviously with a signal strength of 5, My hd locals are not going to come in. Not sure what I am going to do about that. Figure I will give Dish a call and see what they have to say.
Let me know if you have any questions regarding the Tailgater and I will try to answer them.
I think the problem is that his location may be on the edge of the spotbeam (between the green and the yellow in the link below). Not much he can do besides moving to a new location.
SatelliteGuys.US_TheList - Dish Network ALL
Yes, I am right on the edge of the spotbeam. Shouldn't be a big deal for tailgating as our tailgate spot is 35 miles south of my location and should be in a better location for the spotbeam coverage. I know several people in our tailgate area used the winegard gm-1518 last year and had no problems receiving their local channels. As you can see from my signal strengths, the tailgater as expected is not a good at pulling in the strong signals, so it is worth checking the spotbeam maps of where you plan on using your tailgater to ensure you will be able to pickup your locals. I always take an antenna to the tailgate as well to ensure we can watch the games OTA if there is to much rain fade.
Would it be possible to have this setup for use at your home, and then unhook it and take it with you in your RV? Is it compatible with
all satellite tv providers?
Thanks for the detailed post, it sure caught my attention and I want to order one.
It is only compatible with Dish Network. It is built for Tailgating and RV use so I would not recommend using it at home. That is what the stationary Dish 1000.2 & 1000.4 are for.
So, if you're traveling state to state and you stop run setup...selecting state...does the receiver automatically give you the local area stations...that would be a nice, worthwhile feature.
Yes, that would be nice but no, it does not. Once you are beyond your normal locals spot beam you won't get any locals.
Viewsonic Remote Codes 622
Fox attacks Dish's legal moves over autohop
