Telstar 6 satellite (93.0°W) and Telstar 12 at 15.0W
$905.00
magnoan
71
Guys …. I live in Ashland Mass 01721, I have a 30 inch dish and a FSKU-V Universal single LNBF, I was wondering from where I live/ the equipment, can I point my dish and receive :
• Telstar 6 satellite at 93.0°W (Aghapy TV)
• Telstar 12 at 15.0W (Rotana Cinema, Rotana Moussica and Rotana Tarab)
Thanks in advance ….
93w should not be a problem (unless trees or building are in the way)
As far as 15w I don't even know if there is a beam that hits the US.
according to Mike Kohl's site those channels do beam here
MPEG
15.0 West Telstar 12 Ku-Band 10750 MHz local oscillator
H-11959 1209 3/4 08.140
0033 0034 TRACE TV France
1601 1602 SIC NOTICIAS
H-12081 1341 3/4 03.935
0032 0033 BYU-TV Other APIDs: Numerous European
H-12173 1423 3/4 03.503
4130 4131 TV PAMPA Brazil
V-11714 0964 3/4 14.400
0036 0035 CNBC ARABIYA Arabic
0037 0033 ROTANA MOUSSICA Arabic
0038 0034 ROTANA CINEMA Arabic
0100 0110 AL JAZEERA Arabic
0256 0258 ROTANA TARAB Arabic
0754 0756 LBC AMERICA Arabic
Thanks guys so much ….. So with the current equipment I should be ok ?…. Sorry to bother you but I'm new at this , where should I point my dish an what should I set up the dish 2 ?
MPEG
I guess I should have checked Mike's list.
That particular transponder is no longer active. Like everything else here today gone tomorrow.
so the channels dont work any more ? should I try or not worth it !?
Good luck. I can't get my dish over that far with a motor here in the mid-west, but since you are on the coast, maybe you can. Trace TV sounds like it'd be worth looking for.
I cant see that far over (30W is my limit) so I cant comment if they are active
OK thanks for all your help, I'm going to give it a try now, what TP should I use to point the dish, I hate to get no signal because I'm using the wrong TP ?
PS. It say I have to get my LNBF -45, there is no marks/numbers on the LNBF, how do you know what's -45 ?
On Telstar 12 you might want to try Pampasat Brazil at 12173 H 3503, I was getting this quite strongly in Ontario last March when I had a motor. I have no idea if it is still there. BTW this was one of the sats that was outside the range of normal USALS operation, had to switch to 1.2 to hit it.
As for the -45 this sounds like the right skew. If a half turn would turn your lnb upside down, then -45 would be a quarter of that, moving counter clockwise from 12 to 10:30.
Is Russia Today on G 25 Off The Air?
Vertical or not Vertical...that's the question!
