I'm getting very close to upgrading to H/J system.
I want to verify that all my cables will work, specifically the two to my primary TV and one to my back bedroom TV.
My questions are:
1. If I purchase a Hopper and single or duo node, will I be able to test that the three lines will work up to 3000Mhz or will I need to have a Joey installed too for the test?
The cabling in my house is so very difficult that I think an installer might not complete the install if he found we needed to pull new cables. (House on slab and truss attic and no access to outside walls within attic)
2. Will the testing with one Hopper pretty much prove that the cables are OK without activating that simple system as I would want to continue using my VIP stuff until an installer came to install another Hopper/Joey to do the official install?
Hopper with sling now two hundred at Dish Depot making this an interesting exercise, I know I would need to get a single or duo node adding to the cost a little for my test system.
3. Are 75ohm terminators really needed if lots of ports on node will have no connections?
My final system as planned in my mind would be two and maybe three Hoppers and two Joeys.
If my current cables aren't OK, I will then be able to take my time and do the attic crawling, etc. to get the cables upgraded and then call Dish for the install.
__________________
My questions are:
__________________
