I have discovered a couple of things in the last couple of days about putting the right receiver/LNBF with a matching dish.
As most of you know if you read my thread on setting up the Geosat Pro C/Ku LNBF that I decided to make some changes with receivers and what dishes they were controlling.
I have since moved the Geosat Pro LNBF to my Birdview dish and am now controlling that dish with the Traxis 3500 and VBox II.
I moved the Co-rotor to the 10' Unimesh dish and now have the Pansat 3500 controlling the polarity and will have my VBox III controlling dish movement with a GI 450i analog slaved to it. I will also have my PC tuner (SkyStar 2) slaved as well.
I hooked up my new Fortec 5400 to my motorized Primestar 84e.
I discovered during the process that the co-rotor that was on the Birdview dish was the older co-rotor with the ADL patent which Chaparral infringed on and Chaparral has since changed their design to the current style.
I guess that is part of what made everything click together.
The Birdview was so well designed that I popped the Geosat LNBF in there and have not had to make any adjustments to the LNBF at all. I did make a small adjustment on the dish twist. If you remember, I had mentioned that it had moved ever so slightly.
The Unimesh/Pansat is now getting the same outstanding Ku signal that the Pansat/Birdview had been getting previously.
The Traxis/Birdview/Geosat LNBF while not quite as outstanding as the Pansat/Birdview/ADL designed co-rotor was, is still quite acceptable with the added benefit of being able to control multiple LNBFs and 8 port diseqc switches. That mount is where all my multi-dishes with multi-lnbfs come together. BTW, I am getting used to the Traxis, and have learned to like it. It takes some getting used to.
The Fortec 5400 is on a dish that has proven over time to be perfectly tuned and has great performance on Ku. It is doing a great job there, but like the Traxis, I had to learn to like it.
I guess what I am getting at is if you want good signal quality with a voltage controlled LNBF, you need a very well formed parabolic shaped dish with excellent surface accuracy.
If you want good Ku signal quality with a not so good parabolic shaped dish and no so great surface accuracy you need a feed-horn LNBF combo that will enhance the dish's performance.
I would trade my other 3 newer, some only a year old Chaparral co-rotors for the 15 year old ADL designed co-rotors right now if I could find them.
It is all about the right equipment paired with the right receiver. If you do that, you will be a very happy camper.
Fred
Fred
