Over the years, as we changed  from cable to satellite to newer systems etc. the house cabling "evolved" as I adapted it rather than starting over with the ideal setup. With the introduction of biplexers, signal back feeds etc. the (three+ room) cable setup already in place became convoluted with multiple splitters, extra components and unnecessary cabling resulting in substandard signal quality. I'd like to simplify it, regardless, but hopefully to result in higher quality signals.However, I am still a little uncertain about a few issues. I could experiment, disconnect and reconnect everything but I'll bet some of you know the answers off the top of your head saving me a great deal of time ...which I'd appreciate!
As is, remote TV1 location(s) is fed directly from TV1 coax out and remote TV2 location(s) fed directly from TV2 coax out. Is it correct that, with proper use of biplers/triplexers, I could accomplish the same using just one cable routed throughout the house to bring in the satellite signal and feed both TV1 and TV2?
Though the back of the receiver has only TV 2 labelled for "Home distribution" it seems that both TV1 and TV2 are available (I have Modulator setup 44-TV1, 60-TV2) on the coax cable fed from TV1 as well?
So, instead of certain televisions/rooms being designated TV1 or TV2 (with the correct settings, using not monitors but televisions with tuners) "Home distribution" will allow any television to receive material from TV1 or TV2 regardless of whether its connected to TV1 or TV2 (coax)?
Is this correct?
Should the signal quality be the same via either?
Is this correct?
