Upgrading from Old Dish Questions
$835.00
avinstall
9
USA
I'm upgrading from an old dish that received only sd channels to new dish and have a few questions
1. Can I use the 3 LNB Slimline SWM dish to receive local channels or do I need to get the 5 LNB Slimline SWM dish for the Indianapolis area (zip code 46224)?
2. Am I correct if I want to take one of my receivers to my winter home I have to get the exact same setup if I'm moving a HD DVR back and forth?
3. Last question I know my package will change from to get hd channels however if I use Owned receivers which I have checked with the Access Card Distribution Department and are valid owned receivers my contract will not be extended correct?
Thanks for the help
1. The SL3 will be fine. Indy HD is on 99W and the SD versions are on 101
2. That would be the easiest...as long as its a slimline dish you'd be fine. If you get something different you would have to rerun sat setup everytime you move it between locations
3. If you have a HD dish set up there shouldnt be any contract extension. If you add a HD receiver then there would be (but you say they are owned so moot point)
Will an AM21N improve my local network picture?
New Customer offers
