Uplink Activity Report - 02/07/2007 - 251 changes
Why would they remove this feature for many subs.
All the subchannels and PBS are back to where they were a few weeks ago.
Why would they make the EPG data so restrictive?
If they aren't going to provide sub-channel data for locals, then at least change the ViP-622 programming such that Digital Service rating is NR instead of NR/AO. That is how it is on the 811. You can't view PBS Kids here in St. Louis if you have Ratings Locks in effect on the 622. :mad:
I guess I should add to my previous post-
Getting PSIP data is nice, but not the whole deal. IIRC, PSIP is designed to provide current and following program info, and no more. To get listings in the EPG for the next several days means Dish has to pay for the data. PSIP won't do it. They don't want to give it away for free.
If you just hit stop you can delete. You don't have to be at the end of the program to delete.
I realize that, but I shouldn't have to fast forward for an hour after an hour show is over to get to the end. An hour show is supposed to be an hour not two. This is why I think the ota guide data for the sub channels were pulled.
Thats not true, I don't know the technical limit but most stations I get usually have 6 or 12 hours worth and some have 24 hours worth.
My OTA STB's guide will advance out a week but its never that full
PSIP is entirely too vaigue (error-prone) to be reliable for recording purposes, since each station generates it's own data - ITS A MESS - NOBODY USES IT.
Here are some more changes which happened over night, these come to us courtesy of John H who posted these to DBSTalk.
http://www.dbstalk.com/showpost.php?p=822912&postcount=16
I would have posted them myself but I have not got my satellite stuff hooked up to my new TouchSmart PC. :)
191 G4 MOVED FROM Tp 14 on EchoStar 7 at 119w
TO Tp 12 on EchoStar 7 at 119w
204 COURT, COURT REMOVED FROM Tp 2 on EchoStar 7 at 119w
435 FOXNE MOVED FROM Tp 12 on EchoStar 7 at 119w
TO Tp 14 on EchoStar 7 at 119w
502 PPV MOVED FROM Tp 21 on EchoStar 7 at 119w
TO Tp 6 on EchoStar 7 at 119w
5816 VOD MOVED FROM Tp 21 on EchoStar 7 at 119w
7644 KDRV MOVED FROM Tp 10 on EchoStar 2 at 148w
TO Tp 18 on EchoStar 2 at 148w
7645 KTVL MOVED FROM Tp 10 on EchoStar 2 at 148w
7646 KOBI MOVED FROM Tp 10 on EchoStar 2 at 148w
7647 KMVU MOVED FROM Tp 10 on EchoStar 2 at 148w
7650 KSYS MOVED FROM Tp 10 on EchoStar 2 at 148w
7651 KBLN MOVED FROM Tp 10 on EchoStar 2 at 148w
7846 WIS, REMOVED FROM Tp 7s14 on EchoStar 7 at 119w
7950 KTWO MOVED FROM Tp 14 on EchoStar 2 at 148w
TO Tp 4 on EchoStar 2 at 148w
7951 KGWC MOVED FROM Tp 14 on EchoStar 2 at 148w
7952 KCWY MOVED FROM Tp 14 on EchoStar 2 at 148w
7953 KFNB MOVED FROM Tp 14 on EchoStar 2 at 148w
7956 KCWC MOVED FROM Tp 14 on EchoStar 2 at 148w
7991 KTXE MOVED FROM Tp 8 on EchoStar 2 at 148w
TO Tp 12 on EchoStar 2 at 148w
7992 KLST MOVED FROM Tp 8 on EchoStar 2 at 148w
7993 KSAN MOVED FROM Tp 8 on EchoStar 2 at 148w
7994 KIDY MOVED FROM Tp 8 on EchoStar 2 at 148w
9381 KTBY, REMOVED FROM Tp 26 Spotbeam 46 from Cheyenne for EchoStar 10 at 110w
9411 NAUHS MOVED FROM Tp 12 on EchoStar 7 at 119w
TO Tp 11 on EchoStar 7 at 119w
9419 A&E MOVED FROM Tp 20 on EchoStar 3 at 61.5w
TO Tp 22 on EchoStar 3 at 61.5w
9427 UNIHD MOVED FROM Tp 19 on Rainbow 1 at 61.5w
9427 UNIHD MOVED FROM Tp 19 ConUS beam on EchoStar 5 at 129w
TO Tp 27 ConUS beam on EchoStar 5 at 129w
9763 ALLWP ADDED TO Tp 25 on EchoStar 3 at 61.5w
allworship.com
CHANGE COUNT 30
That needs to be a sticky post or a FAQ entry (does this site have that ??). This is exactly why almost no DVR uses PSIP guide data. It's almost useless in regards to a DVR's functionality.
allworship.com
CHANGE COUNT 30
I'm no expert at reading these but I notice some HD was moved....is that more MPEG4 movement?
Something I've been curious about for a while now. If someone was watching - lets say G4 in this case - and it switches transponders as described above - what does the viewer see? Does the screen go blank or does the receiver somehow know to switch to the new transponder?
I would be totally happy with just having any HD OTA added to the guide. Especially PBS. (The other sub PBS stations tend to be remixes of what is on the local primary PBS.) Without the guide data it's a high value HD source waiting to be tapped.
If your PBS stations is part of a translator network (multiple channels in different locations broadcasting the same program schedule), it's possible that Dish only publishes data for the primary station in the network. However, the receiver is not smart enough to know where to look for the data, when it gets mapped down.
For example, the DC / Baltimore area, there are 3 stations that are part of the MPT translator network. Their calls are: WMPT (22 - Annapolis), WFPT (62 - Fredrick), and WBPT (67 - Owing Mills). I can get 62 and 67 reasonably well at my location. However, the 'primary' station is 22. Since the guide data is only provided for 22, none of the data populates for channels 62 or 67. As an aside, Dish does not consider any of the stations to be in the D.C. market, even though the signal covers the entire area. Since WMPT is registered to the Baltimore DMA, it does not matter to them that the translators serve the D.C. market!
I see your point, zero hours is better than 6.
Ref # to the NE PBS OTA guide data problem.
The Nebraska PBS does not use Translators. There all full power normal stations with normal call letters. It covers the whole state.
The Dish OTA guide data did not work. I wonder if its becuase NE PBS puts there HD feed on digital sub channel #5 and not #1 like everyone else. They also do not use the stations call letters for the channel name they change everything to NET-1 NET-2 NET-3 and NET-5 (for Nebraska Educational TV).
The strange channel name along with Im sure other stations around the country doing it also, might of mess up Dishes plan. Just an idea.
I contacted Dish they said it was the stations fault and they needed to change there call letter mapping back to call letters.
Was this subchannel guide data responsible for a bunch of my shows showing "Off Air" on a few channels during prime time and daytime recordings....?
hate to burst your bubble, but they do use translators..bold stuff is satellite stations
http://www.northpine.com/broadcast/ne/tvtranslators.html
Nebraska Educational Television (PBS)
Alliance KTNE/13 316kW Owned & Operated
Basset KMNE/7 316kW Owned & Operated
Beatrice K23AA 17.6kW Owned & Operated
Benkelman K33FO 47kW Owned & Operated
Blair K68AV 110W Owned & Operated
Chadron K06JC 133W Owned & Operated
Crawford K06KR 53W Owned & Operated
Culbertson K44FN 92.4kW Owned & Operated
Decatur K66AR 61W Owned & Operated
Falls City K46FG 16.6kW Owned & Operated
Harrison K08LN 140W Owned & Operated
Hastings KHNE/29 1550kW Owned & Operated
Lexington KLNE/3 100kW Owned & Operated
Lincoln KUON/12 316kW Owned & Operated
McCook K44FN 58.7kW Owned & Operated
Merriman KRNE/12 316kW Owned & Operated
Neligh K65AT 890W Owned & Operated
Norfolk KXNE/19 1700kW Owned & Operated
Niobrara K69BM 3W Owned & Operated
North Platte KPNE/9 316kW Owned & Operated
Omaha KYNE/26 525kW Owned & Operated
Pawnee City K33AC 251W Owned & Operated
Valentine K09IS 8W Government
Verdigre K10JW 13W Owned & Operated
Wauneta K69BN Owned & Operated
Minneapolis is the same way. PBS HD is on -2 here
Vip 622 Chords Question
FCC Must End Local HDTV Disputes
