Vbox X Vs. Vbox 7
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
26,913
7,270
EM75xb
Anybody that has had both notice any real differences between the two, besides physical looks?
I have not owned both, but have worked with both. With help from user NE8E and NickNJen on this site, we've all worked with both. The "X" model has been deployed successfully with two birdviews, requiring a rotary encoder vs. the Birdview original reed switch kit. I use the model 7 with my Birdview, it was less expensive at the time I bought and more readily available. We deploy a different rotary encoder operating at a higher voltage, and a mechanical relay to interpret the pulses to and from the box. Nice thing about the "X" model was, if you need it for our BV conversions, the small circuit board that NE8E built with LED's is visible through the dark plastic lens on the side, so you know its operational!
In a nutshell, unless there's specific needs for your system, either should be fine!
Yeah that's about what I thought. Probably the same guts in a different case and call it a newer model..:)
Isn't there a difference in the number of programmable locations on them? I was thinking the X model had more locations available?
What I read they both have 99
