Can I use this connector:
VGA to 3 RCA component video cable (HD15 - 3-RCA)
To connect the RGB output of my ViP722 to my computer monitor & have the the image display via the 15-Pin VGA input.
The notes on the monoprice site indicate that:
Here is my monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009127&Tpk=x193w
I don't want to waste the money on the cable if it won't work, so I need to find out if the output from the ViP722 is compatible with a newer LCD monitor input.
If anyone knows from the technical end if this will work (especially if you've tried it), please let me know. Or if you know what kind of signal is being output and what is needed for input - that might get me started in the right direction.
Thanks - as always!
IT WILL NOT ALLOW YOU TO CONNECT YOUR COMPONENT VIDEO SOURCES TO A REGULAR COMPUTER MONITOR OR HDTV unless you monitor specifically has this capability. Most do not. (Please check the documentation for your computer monitor)
Here is my monitor:
Thanks - as always!
