Wally Check Switch Daily
$835.00
Abjrjrm
CA
Hello. I have a newer Wally in my RV, and every morning it runs the Check Switch program, which I don't think is normal. I have tried leaving the receiver on at night and turning off the sleep mode, but same issue. Treid changing the rest times, no luck. I have tried leaving the power on and off on my Wingegard powered dish, but same results. Any help? Thanks.
I used to have that problem while using a Tailgater. Turns out it was just a weak signal in the morning humidity and dense air. What dish are you using? Do you have a direct cable from the dish to the receiver, not running it through the RV wiring? Anything you can do to improve signal strength will probably eliminate your problem.
Using Chromecast on a hopper3 to see pictures, etc
DISH Uplink Lockdown Periods
