S
Weingard Square Shooter - OTA Solution- had anyone used?
There had been some real positive feedback on this new antenna from Weingard, maybe we should encourage Voom to look into it.
Here is a copy of one post from Remote Central-
"Just thought I'd let you guys know that I recently discovered a new HD antenna. In the past we specifically used the Channel Master 4228 8 bay and have been pretty happy with it. We were installing them in attics. 95% of the time they worked great the other 5% would drive us crazy.
Anyway, I purchased a weingard "squareshooter" the other day. It comes with a satellite type mast and can mount outside or in the attis. In this case we mounted it outside. We used a Channel master 7777 amp. If you haven't seen one of these antennas yet it is only about 18x18". Needless to say we were a little concerned before we installed it. I told the customer they were a guinea pig and they were fine with that.
The thing worked incredibly!! We ran the cable out the customers window before we mounted it, just in case it was a piece of garbage. It was picking up all of the HD channels on a HD300 receiver signal was all the way to the "d" in "good". And this is while it was laying on the ground."
