Where to buy 6' solid near Twin Cities?
$905.00
sikma
408
Dish Farm Up North
After getting crappy results on ku with a 10' mesh, I'm looking for either 6' or an 8' solid. I'd like to avoid shipping charges and just pick it up in person............I'm close to the St. Paul / Minneapolis area.....
Try Radio City in Mounds View. It is a ham radio store, but they have all kinds of electronics. I was there several years ago and it is cool :-)
havent tried on the KU side because my LNB's are for offset dishes
I have just the C-band LNBF
I had very decent results with a 6' mesh dish and Ku signals, the trick is that the Ku signals will not be at the same azimuth as C-Band signals, also you have to optimise the skew for Ku signals and the C-Band signals will drop slightly!
"I know where a 6" solid dish is that may be available for free (Would need taken down from the roof of a bar)
Believe me, I tried 'peaking' az/el the whole ball of wax when I had the bsc621 on the 10' mesh, still terrible ku results. I lost about 20 points of signal vs. my .4 Fortec that is one one of my 36" P* dishes. I think my only alternative is to get a larger solid dish (6 or 8') to pull in both c/ku signals.
p.s. regarding the possible free 6-footer on the bar....I'm not to keen on heights.....how big of a job would it be?
Its pretty high, so may be a 2 man job.
Backyard Bar and Grill, Richfield just of I-494
Its pointing at the ground to the east, been that way for many a year!
I am sure you would pass about 10 free solid BUD's on the way to get it :)
Thanks PSB.....I think I'll pass and keep looking...maybe I'll go after one from Sadoun.........used them before, good folks
Sadoun said:
Thank you. Here are the Fortec C-Band dishes we have in stock now:
http://sadoun.com/Sat/Order/Dishes/C_Band_satellite_dish.htm
I'm looking for the best solid dish to get c/ku using my bsc621 c/ku lnbf. I will also need a polar mount as I will hooking the mount to a von weise actuator that I currently have on a P* dish. Will I be able to retro-fit my current polar mount (it's for a 10' mesh, but I've already retroed it to work with a P* dish) or will I have to buy a polar mount specifically for the Fortec?
Sikma,
The mash dish is not yore problem the problem is the C/KU LNBF.
Get yore self a real feed horne like the Chaparral C/KU CoRotor II plus and stop messing with those imitation C/KU LNBFs
Have one, prefer the BSC 621-2 one coax cable does it all.
I am getting good results with a 6' mesh dish on Ku signals :up
I did optimise the LNBF for Ku signals (Including modifying the LNB cover) adjusting the skew and F/D while locked on a ku signal. C-band signals did suffer but the end results were worth it.
A View of my DishFarm
Happy Birthday-Iceberg!!!
