Which generations of tuners works with 3 LNB's?
Andrewwski
1,205
4
Sorry if this has been answered before...I searched these forums as well as the internet and cannot come up with an answer.
Which generations of DirecTV receivers work with a 3 LNB dish? I assume first generation tuners (such as RCA model DRD203RW) do not work?
Thanks in advance!
Thanks...however I don't see a mention of compatibilty with a 3 LNB dish in there.
Thanks in advance!
They do work,but only on the 101 satellite. If you have 3lnb dish then you must have a "Multi -Satellite receiver",If you want 110 and 119 .Otherwise your only going to receive programming from the 101 satellite. The very first RCA's are not. I have one.If you buy a receiver just make sure it says MULTI SATELLITE RECEIVER
Thanks...that's what I thought. Is there any list somewhere that shows what channels are on which satellite?
Looks like I'll probably be buying a new one.
Also the access card thats in your receiver is most likely out of date ,so you will have to buy a new one from Directv. I think its still around $20.
Directv Plus receivers will receive all 3 sats on a 3 LNB dish. Unless your locals come off 119 or you want Spanish or Chinese programming 101 is all you need to receive.
I just figured that out from the list. Thanks!
Looks like all I need now is to order an access card.
HR-20 Internal Temp
Sac Area and other ?s
