xfer shows from 622 to 722
stugots48
29
Are there any problems xfering shows from a 622 to a usb drive then to a 722?
thanks.
thanks, I do have the usb drive activated and both receivers are on my account. I will do the xfer this weekend.
Isn't there a limit to the number of swaps one can do? I thought it was three times and your done.
I think you may be right on this, it shouldn't matter to the OP as he is transfering them twice. Once to the hard drive and once to the other receiver (although they can be played through the hard drive on the other receiver, I'm not sure if this setup would count as a transfer..
Why do you say that? It's not true. I did just that and had no problems.
It sounded like he wanted to go 622->drive, and then drive -> 722. You can just move the hard drive between the two, but can't use the drive as just a transfer medium and end up with shows in your 722 from your 622.
It is done. I moved the shows from the 622 to the usb drive. I then connected the usb drive to the 722 and restored the shows to the 722 with no problem. Thanks all.
1 dish 4 receivers
Will, they take my old dish when I upgrade?
