to Satelliteguys apmoco!
Isn't the BS1H3UP250M a dish? If so, it's the older ku type. That means it won't work (well) for hd signals. The lnb #232594 is really a
BSCH84P01, which looks like a ku type also. No good for hd if that's what you are looking for. They would work for 101, 110, and 119 only.
What is it that you hope to end up with?I will probably have to toggle between the low def satellites w/o a dual....any thoughts?
I'm asking the question because I don't know what the goal is. I thought that was self-evident.Why are you asking questions when you don't know what's going on?
I agree,I'm asking the question because I don't know what the goal is. I thought that was self-evident.
It is much more economical to understand the whole problem before posting numerous replies.
I think what I have gathered is in order to receive 2 satellites at once you have to skew the dish (azimuth, elevation, skew). The roof top mount on the RV allows for azimuth and elevation only. I would imagine if you positioned the dish between lets say 101 and 110 you would not get much of a signal.....any thoughts?
The pinnacle of DIRECTV dish technology back then was the Phase III dish that received all three slots and could supply up to four tuners with signal. RV tech typically trailed in-home tech. From what I've been able to gather, the DISH you gave us the number for is a round dish designed for a single LNB.Probably, 2003 RV original install. That was most likely the tech back then. Just thought a new LNB may let me receive multiple birds. I do not think it is possible due to skew and the dish will not. I will try to be more precise next time.
If you're going to move around a lot, a ground-based dish might make more sense as going up and down the Cascade Range will involve lots of tweaking of the dish elevation. As an example, a Phoenix dish points 14.7 degrees higher in the sky than does a Eugene dish and a Eugene multi-slot dish must be tilted about 10 degrees more than the same dish in Phoenix.
A single LNB dish such as the one you have will give you access to programming on 101W and that represents much (but far from all) of DIRECTV's national SD programming. Because the guide data resides at 101W, you may or may not be able to re-aim to 119W and have it work.
