Visionsat IV200 PVR Plus
still doesn't show it but you should be able to use Brazilsat at 84.0W and just rename it...that's what I did :)
But that brings up the motor issue. Let me check tonite if you can change the satellite location
Thanks Iceberg, I appreciate it! :) I actually have a Visionsat on the way here, still have to pick out a motor tough. I've decided the 3ABN $50 dish should be a good candidate for motorization. :D
I received my Visionsat today and when I updated it to the 9-19 firmware from VisionSat I was elated to learn that it includes the AMC 2 satellite at 85W!
I was waiting on the giveaway today..I didn't want to jinx myself...:)
I've had one of these for about 2 weeks now. I am either a dumbkopf or this is the most confusing thing I've ever seen. Blind scan....WHY does it have to load TP info EVERY time it blindscans? Blind scan IS finding the TP's, I thought.
With the old firmware, it was much better at ID'ing channels, the new 1.12 firmware broke that, it just says CD1, CD2, etc.
I have a audio issue with the radio side. I was sitting listening to the audio on E* 7 and it just went silent. I put it back on the video side ( NASA channel ) and still no sound. Put it in standby, turned it back on, still no sound. So I started pressing buttons until something happened. When I pressed the MUTE button, and pressed it AGAIN,whammo, sound. It did the same thing three times that same night, and twice the following night. I emailed Visionsat, received a nice return email instructing me to call them. I did, they requested that I do a factory reset and try again. I did that, and am still having the same issue.
Its also very flaky on a switch. It will just drop signal for no reason, and you have to do a hard power off (using the switch on the back) to get it to work the disecq switch again.
I either got a bad one or this thing is very flaky. Other than that I like how its laid out, it has great use of color, menus are pretty clear, although the scan functions are confusing to me.:)
Don't think it's your problem Stogie. Downloaded Ver 1.12 and minedoes the same thing. Good thing I saved Ver 1.1. Going back to that.
todd
todd
You know, in a way, that's a relief. I thought I was going CRAZY. !sadroll
It does seem like Visionsat is interested in making it better as a platform though, so maybe they'll fix it. :)
Someone answer this stupid question for me. A regular disecq switch....is that 1.0, 1.2, or what on the Visionsat? That may be my issue with the switch, bad setup. I am going to move this receiver into my bedroom to replace the Sonicview 4000 in there, its so flaky on the motor I am gonna give the Visionsat a try. :up
That's something that Iceberg can answer.
Update on Ver 1.12. Before I re-installed Ver 1.1 I deleated G10r and did a blind search and everything returned. The only problem with that is why have to rescan all the birds everytime they change Version's? I saved everything and reinstalled the channel data, which is where I ran into the sound problem.
todd
Well then my Visionsat has a diseqc problem then. It will not reliably switch when scanning a new sat. I have been banging my head against the wall today scanning c-band satellites, I have to turn the box off every time I scan a new satellite or it WILL NOT see port 2 of the switch. I have my 119 dish on port 1 set diseqc 1.0, and my cband feed coming from the multiswitch on port 2,again diseqc 1.0.
In any case,tomorrow it is going in my bedroom on the motor I just got back from DMS. I am still having issues, and I think its the Sonicview, it never was any good with a motor in the first place, so I going to try the Visionsat on that dish, and put the SonicView on the C Band/ 119 combo.
Thanks for the info.:up
Okay.. this is what I have, how do I save the position? USALS is off for me, way off...maybe 10 degrees.
EDIT: Nevermind, I rooted around and found it.....I am a doofus...working on getting the sats all stored in...I got ONE so far...
USALS is broken on this receiver too. In entered it just like I have it in my Coolsat 5000 and it will not hit ANY satellite. I tried to recalibrate it on AMC6 then go west satellite by satellite...never hit a one. Have to do it manually.
It also will NOT switch my disecq switch. I took it out of the loop and the receiver works fine. Put it back in, no signal. grrrrrrr......
Hi,
Could someone please post version 1.1 of the Visionsat firmware? I am having problems blind scanning with v 1.12. Thanks! :)
EDIT: Nevermind, I found a copy of 1.11 that Iceberg posted.
Has anyone noticed that the Visionsat freezes up when it goes to a 4:2:2 feed? There are a few on AMC1, and whenever I change the channel to one the box locks up and needs to be powered down from the back power switch. I know that it can't decode the video, but I didn't expect it to lock up. :( I'm using the 1.11 firmware.
Hi,
Yep. Mine does it too. :(
10x1 DiSEqC Switch Review
Neusat HD 9000 Receiver Review
