Cleveland - WJWDT
jvadas
14
Newton Falls, OH
I live in Newton Falls, OH (44444). I am having problems pulling in Fox8-HD(WJW). I built a home made antenna(8 bay UHF) to watch the superbowl. With my Winegard 8275 pre-amp my signal was at 85%. Weeks after the superbowl, I noticed my that my signal was dropping a little day by day until it reached zero. Since then I have add a new antenna (winegard 8200u) and added new coax(rg6 about 100 feet) and I can not WJW at all. I can get all of the other Cleveland stations except WJW. I know that WJW is currently broadcasting on channel 31. Are they putting out less power than before? Is there anything that I can do to try and pull in this station? Thanks
Wjs
I live in Newton Falls, OH (44444). I am having problems pulling in Fox8-HD(WJW). I built a home made antenna(8 bay UHF) to watch the superbowl. ... Are they putting out less power than before? Is there anything that I can do to try and pull in this station? Thanks
Comes in OTA as before for me in Akron.
JVADAS are you using a rotor on your present setup, if not I was wondering scince your aimed at Cleveland how do the locals come in like WKBN, WFMJ, WNEO, and what the heck WYTV.
Yes I have a rotor. Channel Master 9521. When I have my 8200u pointed toward Cleveland, Wfmj at 90%, Wkbn at 95% and WYTV at 60%
The other night I was playing around and tuner 1 of my directv box(hr20-700) read 90% for WJW. I went to the channel and it gave me the searching for signal.
Thats perfect, I'm surprised your getting WYTV on the back side I cant get any signal at all from them and yet I get channel 5 from cleveland in great. About how many channels do you get. Right now I get 19 with an omnidirectional antenna.
Here are the stations I get from zip 44444 using a Winegard 8200u, winegard 8275 pre amp, and a channel Master 9521 Rotot.
WFMJ-DT21.1
WKBN-DT27.1
WYTV-DT
WNEO-DT
WKYC-DT3.1&3.2
WEAO-DT50.1
WEWS-DT5.1
WNIO-DT19.1&19.2
Plus a lot of others that i took out of my guide. Stations that I will not watch.....
I'm not that far from him actually a couple miles and I get it fine, 6 out of 10 bars on my signal meter with a so so antenna. You said you added an antenna do you have two connected at once?
No I just have the 8200u. My signal meters jump all over the place. They always have, did not matter what antenna I had hooked up or anything. I have all new coax installed also cause I thought that might be the problem.
Like I said before I did receive WJW via a home made 4228, but the signal just faded away to nothing.
SAP - Secondary Audio Programming
OTA Upgrade/Setup
