CD writing problem
120inna55
1,454
31
Athens, Texas, United States
Recently my desktop PC's HDD died, so I had another PC built using the same tower (new mobo/processor, new HDD, new DVDRW) Kept old DVD-ROM.
Previously I copied discs (CD's only--data and cda). It was only a CDRW (not DVD RW). The CDs I used for copying were CD-R's, but I have no idea as to the 'speed' rating of the discs. They are Sony's and they just say CD-R, 80min (I believe) They're on a spindle and the label's gone.
The new system has the following: Lite-On (model: LH-20A1S) sATA: Lite-On IT Corporation Global - LH-20A1S: Features : Features
The source DVD-ROM drive is an older Samsung 16E SD-616F.
Whenever I attempt to copy any music CD (I've randomly chosen about 4 different discs ranging from old to new). The progress gets to about 25%, then Nero says it failed. Specifically it says "disc read error."
So I tried ripping MP3's and then burning via Windows xP. The MP3's ripped fine, but again, Windows error'ed after about 25% progress.
Burning a small amount of data seems to do OK via Windows. But if I try to burn more than say 1/2 the capacity of the disc, I get an error.
The shop that built the PC for me humored me and allowed me to swap out the Lite-On burner. Still the same problem persists.
I tried making Nero burn at 12x, but I got the same problem (I couldn't find an option to make Nero burn any slower, but I admittedly didn't look very hard).
Since I've tried burning things directly from another disc, burning directly from my HDD, used Nero, used Windows---I've come to the conclusion that it must be the blank media. Is my logic sound?
Could it be that the reason I didn't have a problem previously is because the older drive was slow, relatively speaking, and thus the discs were compatible? I've probably had the spindle of CD-R's for a year.
This stuff is really foreign to me, so I really need some guidance here. I guess I'll go buy some more blank CD-R's, but I really don't know what to buy.
Thanks for any advice you may have.
Since someone built this for you and added all the components to their specs, I would take the pc to that shop and ask them to try burning a cd and see what happens. They need to make it work correctly, otherwise you are not getting what you paid for.
Agreed. And that would be my next step. It's just a pain to disconnect everything and lug the big 'ole thing in. Not to mention the down time.
Could my problem simply be blank media related?
Possibly, but most CD blanks burn fairly reliably these days. If it was DVD blanks, I would say yes.
DVD burners do not always make good cd burners.
Bought some new CD-R's and still having the same problem. The problem persists whether I write from an image off the HDD or directly from the DVD-ROM.
Slowing it down to 16x made no difference.
Here's the error log:
Code:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 11/2/2004 12:54:32 PM
NT-SPTI used
Nero Version: 7.5.13.1
Internal Version: 7, 5, 13, 1
 (Nero Express)
Recorder:             <LITE-ON DVDRW LH-20A1S>  Version: 9L08 - HA 1 TA 0 - 7.5.13.1
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2048kB
 Bus Type      :      via Inquiry data (1) -> ATAPI, detected: ?
 Connected to MMC as unknown drive with class-nr : 1
 Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM:               <SAMSUNG  DVD-ROM SD-616F >Version: F100 - HA 1 TA 1 - 7.5.13.1
=== Scsi-Device-Map ===
DiskPeripheral       : WDC WD1600AAJS-00B4A0            atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : LITE-ON DVDRW LH-20A1S           atapi Port 1 ID 1  DMA: On
CdRomPeripheral      : SAMSUNG DVD-ROM SD-616F          atapi Port 3 ID 0  DMA: On
DiskPeripheral       : IOMEGA ZIP 100                   atapi Port 3 ID 1  DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LH-20A1S     D:   CDRom0
SAMSUNG DVD-ROM SD-616F    F:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE           : 0
Physical memory     : 1022MB (1046956kB)
Free physical memory: 665MB (681116kB)
Memory in use       : 34 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
29.4.2008
===== Disc-Copy over image - 1st step : Copy to image  ...
6:02:54 PM	#1 Text 0 File SCSIPTICommands.cpp, Line 411
	LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:02:55 PM	#2 Text 0 File SCSIPTICommands.cpp, Line 209
	SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
6:02:55 PM	#3 Phase 48 File dlgbrnst.cpp, Line 1760
	Analyzing disc
6:02:55 PM	#4 CDCOPY -1 File CDCopy.cpp, Line 1916
	The CD is copyrighted
6:02:55 PM	#5 Text 0 File CDCopy.cpp, Line 2132
	          _Index0_ _______Index1_______ PostPause   ___LastBlockOfTrack_
	Track  1:        0        0 (  0:02.00)     17847      17846 (  3:59.71)
	Track  2:    17847    17847 (  3:59.72)     30762      30761 (  6:52.11)
	Track  3:    30762    30762 (  6:52.12)     51212      51211 ( 11:24.61)
	Track  4:    51212    51212 ( 11:24.62)     66577      66576 ( 14:49.51)
	Track  5:    66577    66577 ( 14:49.52)     84575      84574 ( 18:49.49)
	Track  6:    84575    84575 ( 18:49.50)    104622     104621 ( 23:16.71)
	Track  7:   104622   104622 ( 23:16.72)    119222     119221 ( 26:31.46)
	Track  8:   119222   119222 ( 26:31.47)    138730     138729 ( 30:51.54)
	Track  9:   138730   138730 ( 30:51.55)    152512     152511 ( 33:55.36)
	Track 10:   152512   152512 ( 33:55.37)    166102     166101 ( 36:56.51)
	Track 11:   166102   166102 ( 36:56.52)    183717     183716 ( 40:51.41)
	Track 12:   183717   183717 ( 40:51.42)    196287     196286 ( 43:39.11)
6:02:55 PM	#6 Text 0 File CDCopy.cpp, Line 840
	Copy options:	copy on-the-fly:  ON
		read ISRC/MCN: OFF
		use jitter correction: OFF
		data options
			ignore read error:  ON   write defekt blocks OFF
			read raw data: OFF   read r-w subchannel data: OFF
		audio options
			read indexes: OFF    read r-w subchannel data: OFF
	source disc does not look like CD Extra
	01.      0 -  17847 =  17847, audio (TRM_AUDIO_NOPRE, block size 2352)
	02.  17847 -  30762 =  12915, audio (TRM_AUDIO_NOPRE, block size 2352)
	03.  30762 -  51212 =  20450, audio (TRM_AUDIO_NOPRE, block size 2352)
	04.  51212 -  66577 =  15365, audio (TRM_AUDIO_NOPRE, block size 2352)
	05.  66577 -  84575 =  17998, audio (TRM_AUDIO_NOPRE, block size 2352)
	06.  84575 - 104622 =  20047, audio (TRM_AUDIO_NOPRE, block size 2352)
	07. 104622 - 119222 =  14600, audio (TRM_AUDIO_NOPRE, block size 2352)
	08. 119222 - 138730 =  19508, audio (TRM_AUDIO_NOPRE, block size 2352)
	09. 138730 - 152512 =  13782, audio (TRM_AUDIO_NOPRE, block size 2352)
	10. 152512 - 166102 =  13590, audio (TRM_AUDIO_NOPRE, block size 2352)
	11. 166102 - 183717 =  17615, audio (TRM_AUDIO_NOPRE, block size 2352)
	12. 183717 - 196287 =  12570, audio (TRM_AUDIO_NOPRE, block size 2352)
6:03:03 PM	#7 Text 0 File Burncd.cpp, Line 3467
	Turn on Disc-At-Once, using CD-R/RW media
6:03:03 PM	#8 Text 0 File DlgWaitCD.cpp, Line 306
	Last possible write address on media:   445499 ( 99:01.74)
	Last address to be written:             196286 ( 43:39.11)
6:03:03 PM	#9 Text 0 File DlgWaitCD.cpp, Line 318
	Write in overburning mode: NO (enabled: CD)
6:03:03 PM	#10 Text 0 File DlgWaitCD.cpp, Line 490
	>>> Protocol of DlgWaitCD activities: <<<
6:03:03 PM	#11 Text 0 File ThreadedTransferInterface.cpp, Line 792
	Setup items (after recorder preparation)
	 0: TRM_AUDIO_NOPRE (1 - Audio)
	    2 indices, index0 (150) not provided
	    original disc pos #0 + 17847 (17847) = #17847/3:57.72
	    relocatable, disc pos for caching/writing not required/not required
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17847 blocks [Image Recorder]
	 1: TRM_AUDIO_NOPRE (2 - Audio)
	    2 indices, index0 (0) provided
	    original disc pos #17847 + 12915 (12915) = #30762/6:50.12
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12915 blocks [Image Recorder]
	 2: TRM_AUDIO_NOPRE (3 - Audio)
	    original disc pos #30762 + 20450 (20450) = #51212/11:22.62
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20450 blocks [Image Recorder]
	 3: TRM_AUDIO_NOPRE (4 - Audio)
	    original disc pos #51212 + 15365 (15365) = #66577/14:47.52
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15365 blocks [Image Recorder]
	 4: TRM_AUDIO_NOPRE (5 - Audio)
	    original disc pos #66577 + 17998 (17998) = #84575/18:47.50
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17998 blocks [Image Recorder]
	 5: TRM_AUDIO_NOPRE (6 - Audio)
	    original disc pos #84575 + 20047 (20047) = #104622/23:14.72
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20047 blocks [Image Recorder]
	 6: TRM_AUDIO_NOPRE (7 - Audio)
	    original disc pos #104622 + 14600 (14600) = #119222/26:29.47
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14600 blocks [Image Recorder]
	 7: TRM_AUDIO_NOPRE (8 - Audio)
	    original disc pos #119222 + 19508 (19508) = #138730/30:49.55
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19508 blocks [Image Recorder]
	 8: TRM_AUDIO_NOPRE (9 - Audio)
	    original disc pos #138730 + 13782 (13782) = #152512/33:53.37
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13782 blocks [Image Recorder]
	 9: TRM_AUDIO_NOPRE (10 - Audio)
	    original disc pos #152512 + 13590 (13590) = #166102/36:54.52
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13590 blocks [Image Recorder]
	10: TRM_AUDIO_NOPRE (11 - Audio)
	    original disc pos #166102 + 17615 (17615) = #183717/40:49.42
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17615 blocks [Image Recorder]
	11: TRM_AUDIO_NOPRE (12 - Audio)
	    original disc pos #183717 + 12570 (12570) = #196287/43:37.12
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12570 blocks [Image Recorder]
6:03:03 PM	#12 Text 0 File ThreadedTransferInterface.cpp, Line 995
	Prepare [Image Recorder] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	 TOCType: 0x00; Session Closed, disc fixated
	 Tracks 1 to 12:                                  Idx 0         Idx 1      Next Trk
	   1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos             0        352800      42328944, ISRC ""
	   2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      42328944      42328944      72705024, ISRC ""
	   3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos      72705024      72705024     120803424, ISRC ""
	   4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     120803424     120803424     156941904, ISRC ""
	   5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     156941904     156941904     199273200, ISRC ""
	   6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     199273200     199273200     246423744, ISRC ""
	   7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     246423744     246423744     280762944, ISRC ""
	   8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     280762944     280762944     326645760, ISRC ""
	   9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     326645760     326645760     359061024, ISRC ""
	  10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     359061024     359061024     391024704, ISRC ""
	  11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     391024704     391024704     432455184, ISRC ""
	  12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos     432455184     432455184     462019824, ISRC ""
	DAO layout:
	 ___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
	     -150 |  lead-in |   0 |    0x01 |        0 |        0 | 0x00
	     -150 |        1 |   0 |    0x01 |    17847 |    17697 | 0x00
	        0 |        1 |   1 |    0x01 |    17847 |    17847 | 0x00
	    17847 |        2 |   0 |    0x01 |    12915 |    30762 | 0x00
	    17847 |        2 |   1 |    0x01 |    12915 |    30762 | 0x00
	    30762 |        3 |   0 |    0x01 |    20450 |    51212 | 0x00
	    30762 |        3 |   1 |    0x01 |    20450 |    51212 | 0x00
	    51212 |        4 |   0 |    0x01 |    15365 |    66577 | 0x00
	    51212 |        4 |   1 |    0x01 |    15365 |    66577 | 0x00
	    66577 |        5 |   0 |    0x01 |    17998 |    84575 | 0x00
	    66577 |        5 |   1 |    0x01 |    17998 |    84575 | 0x00
	    84575 |        6 |   0 |    0x01 |    20047 |   104622 | 0x00
	    84575 |        6 |   1 |    0x01 |    20047 |   104622 | 0x00
	   104622 |        7 |   0 |    0x01 |    14600 |   119222 | 0x00
	   104622 |        7 |   1 |    0x01 |    14600 |   119222 | 0x00
	   119222 |        8 |   0 |    0x01 |    19508 |   138730 | 0x00
	   119222 |        8 |   1 |    0x01 |    19508 |   138730 | 0x00
	   138730 |        9 |   0 |    0x01 |    13782 |   152512 | 0x00
	   138730 |        9 |   1 |    0x01 |    13782 |   152512 | 0x00
	   152512 |       10 |   0 |    0x01 |    13590 |   166102 | 0x00
	   152512 |       10 |   1 |    0x01 |    13590 |   166102 | 0x00
	   166102 |       11 |   0 |    0x01 |    17615 |   183717 | 0x00
	   166102 |       11 |   1 |    0x01 |    17615 |   183717 | 0x00
	   183717 |       12 |   0 |    0x01 |    12570 |   196287 | 0x00
	   183717 |       12 |   1 |    0x01 |    12570 |   196287 | 0x00
	   196287 | lead-out |   1 |    0x01 |        0 |        0 | 0x00
6:03:03 PM	#13 Phase 120 File dlgbrnst.cpp, Line 1760
	Creating the image for burning
6:03:03 PM	#14 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
6:03:03 PM	#15 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #17847): write at #17847
6:03:03 PM	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #30762): write at #30762
6:03:03 PM	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #51212): write at #51212
6:03:03 PM	#18 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #66577): write at #66577
6:03:03 PM	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #84575): write at #84575
6:03:03 PM	#20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #104622): write at #104622
6:03:03 PM	#21 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #119222): write at #119222
6:03:03 PM	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #138730): write at #138730
6:03:03 PM	#23 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #152512): write at #152512
6:03:03 PM	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #166102): write at #166102
6:03:03 PM	#25 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #183717): write at #183717
6:06:08 PM	#26 Text 0 File WriterStatus.cpp, Line 113
	<Image Recorder> start writing Lead-Out at LBA 196287 (2FEBFh), length 0 blocks
6:06:08 PM	#27 Phase 121 File dlgbrnst.cpp, Line 1760
	Creating Image completed successfully
6:06:09 PM	#28 Text 0 File SCSIPTICommands.cpp, Line 254
	SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
6:06:13 PM	#29 Text 0 File SCSIPTICommands.cpp, Line 411
	UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:06:13 PM	#30 Text 0 File Cdrdrv.cpp, Line 10538
	DriveLocker: UnLockVolume completed
===== Disc-Copy over image - 2nd step : Burn the image ...
6:06:14 PM	#1 Text 0 File SCSIPTICommands.cpp, Line 411
6:06:14 PM	#2 Text 0 File Burncd.cpp, Line 3156
	SMART-BURN activated
6:06:14 PM	#3 IMAGEGEN -10 File ImageGen.cpp, Line 366
	Image was written as DAO.
	DAOI:
	 MediaCatalogNumber = ''
	 TocType = 0x00
	 Finalized =  1
	 First/Last Track =  1 / 12
	  1: ISRC = ''
	     Blocksize = 2352
	     TrackMode = 'TRM_AUDIO_NOPRE'
	     TrackConfig = 0x00
	     First/Last Index =  0 /  1
	     Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 42328944
	  2: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 42328944, Index1FilePos = 42328944, NextTrackFilePos = 72705024
	  3: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 72705024, Index1FilePos = 72705024, NextTrackFilePos = 120803424
	  4: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 120803424, Index1FilePos = 120803424, NextTrackFilePos = 156941904
	  5: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 156941904, Index1FilePos = 156941904, NextTrackFilePos = 199273200
	  6: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 199273200, Index1FilePos = 199273200, NextTrackFilePos = 246423744
	  7: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 246423744, Index1FilePos = 246423744, NextTrackFilePos = 280762944
	  8: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 280762944, Index1FilePos = 280762944, NextTrackFilePos = 326645760
	  9: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 326645760, Index1FilePos = 326645760, NextTrackFilePos = 359061024
	 10: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 359061024, Index1FilePos = 359061024, NextTrackFilePos = 391024704
	 11: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 391024704, Index1FilePos = 391024704, NextTrackFilePos = 432455184
	 12: ISRC = ''
	     Blocksize = 2352
	     TrackConfig = 0x00
	     Index0FilePos = 432455184, Index1FilePos = 432455184, NextTrackFilePos = 462019824
	CUES:
	   0: Ctrl=0x01 Trk=  0 (0x00) Index=00 Start=954437:08.46 (     -150) RecDep=0x00
	   1: Ctrl=0x00 Trk=  1 (0x01) Index=04 Start=3801:08.52 ( 17105152) RecDep=0x11 [empty/reserved]
	MTYP: Mediumtype =  CD (old format) (0x1)
	Image file name: <C:\Documents and Settings\Hilton\My Documents\TempImage.nrg>
6:06:14 PM	#4 Text 0 File Burncd.cpp, Line 3467
6:06:14 PM	#5 Text 0 File DlgWaitCD.cpp, Line 306
	Last possible write address on media:   359845 ( 79:59.70)
6:06:14 PM	#6 Text 0 File DlgWaitCD.cpp, Line 318
6:06:15 PM	#7 Text 0 File DlgWaitCD.cpp, Line 2929
	Recorder: LITE-ON DVDRW LH-20A1S;
	   CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc.
	   ATIP Data:
	     Special    Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 47 (LO 79:59.71)
	     Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
6:06:15 PM	#8 Text 0 File DlgWaitCD.cpp, Line 490
6:06:15 PM	#9 Text 0 File ThreadedTransferInterface.cpp, Line 792
	    2 indices, index0 (150) provided
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17847 blocks [D: LITE-ON DVDRW LH-20A1S]
	    2 indices, index0 (0) not provided
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12915 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20450 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 15365 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17998 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20047 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14600 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19508 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13782 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13590 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 17615 blocks [D: LITE-ON DVDRW LH-20A1S]
	    -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 12570 blocks [D: LITE-ON DVDRW LH-20A1S]
6:06:15 PM	#10 Text 0 File ThreadedTransferInterface.cpp, Line 995
	Prepare [D: LITE-ON DVDRW LH-20A1S] for write in CUE-sheet-DAO
	DAO infos:
	 MCN: ""
	DAO layout:
	     -150 |        1 |   0 |    0x01 |    17847 |     -150 | 0x00
	        0 |        1 |   1 |    0x01 |    17847 |        0 | 0x00
	    17847 |        2 |   0 |    0x01 |    12915 |    17847 | 0x00
	    17847 |        2 |   1 |    0x01 |    12915 |    17847 | 0x00
	    30762 |        3 |   0 |    0x01 |    20450 |    30762 | 0x00
	    30762 |        3 |   1 |    0x01 |    20450 |    30762 | 0x00
	    51212 |        4 |   0 |    0x01 |    15365 |    51212 | 0x00
	    51212 |        4 |   1 |    0x01 |    15365 |    51212 | 0x00
	    66577 |        5 |   0 |    0x01 |    17998 |    66577 | 0x00
	    66577 |        5 |   1 |    0x01 |    17998 |    66577 | 0x00
	    84575 |        6 |   0 |    0x01 |    20047 |    84575 | 0x00
	    84575 |        6 |   1 |    0x01 |    20047 |    84575 | 0x00
	   104622 |        7 |   0 |    0x01 |    14600 |   104622 | 0x00
	   104622 |        7 |   1 |    0x01 |    14600 |   104622 | 0x00
	   119222 |        8 |   0 |    0x01 |    19508 |   119222 | 0x00
	   119222 |        8 |   1 |    0x01 |    19508 |   119222 | 0x00
	   138730 |        9 |   0 |    0x01 |    13782 |   138730 | 0x00
	   138730 |        9 |   1 |    0x01 |    13782 |   138730 | 0x00
	   152512 |       10 |   0 |    0x01 |    13590 |   152512 | 0x00
	   152512 |       10 |   1 |    0x01 |    13590 |   152512 | 0x00
	   166102 |       11 |   0 |    0x01 |    17615 |   166102 | 0x00
	   166102 |       11 |   1 |    0x01 |    17615 |   166102 | 0x00
	   183717 |       12 |   0 |    0x01 |    12570 |   183717 | 0x00
	   183717 |       12 |   1 |    0x01 |    12570 |   183717 | 0x00
6:06:15 PM	#11 Text 0 File SCSIPTICommands.cpp, Line 209
6:06:15 PM	#12 Phase 36 File dlgbrnst.cpp, Line 1760
	Burn process started at 24x (3,600 KB/s)
6:06:15 PM	#13 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 0 (relocatable, no disc pos, patch infos, orig at #0): write at #0
6:06:15 PM	#14 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 1 (relocatable, no disc pos, patch infos, orig at #17847): write at #17847
6:06:15 PM	#15 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 2 (relocatable, no disc pos, patch infos, orig at #30762): write at #30762
6:06:15 PM	#16 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 3 (relocatable, no disc pos, patch infos, orig at #51212): write at #51212
6:06:15 PM	#17 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 4 (relocatable, no disc pos, patch infos, orig at #66577): write at #66577
6:06:15 PM	#18 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 5 (relocatable, no disc pos, patch infos, orig at #84575): write at #84575
6:06:15 PM	#19 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 6 (relocatable, no disc pos, patch infos, orig at #104622): write at #104622
6:06:15 PM	#20 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 7 (relocatable, no disc pos, patch infos, orig at #119222): write at #119222
6:06:15 PM	#21 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 8 (relocatable, no disc pos, patch infos, orig at #138730): write at #138730
6:06:15 PM	#22 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 9 (relocatable, no disc pos, patch infos, orig at #152512): write at #152512
6:06:15 PM	#23 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 10 (relocatable, no disc pos, patch infos, orig at #166102): write at #166102
6:06:15 PM	#24 Text 0 File ThreadedTransferInterface.cpp, Line 2712
	Verifying disc position of item 11 (relocatable, no disc pos, patch infos, orig at #183717): write at #183717
6:06:15 PM	#25 Text 0 File MMC.cpp, Line 17597
	StartDAO : CD-Text - On
6:06:15 PM	#26 Text 0 File MMC.cpp, Line 22275
	Set BUFE: SMART-BURN -> ON , SMART-BURN : ON
6:06:15 PM	#27 Text 0 File MMC.cpp, Line 17827
	CueData, Len=120
	01 00 00 41 00 00 00 00
	01 01 00 00 00 00 00 00
	01 01 01 00 00 00 02 00
	01 02 01 00 00 03 3b 48
	01 03 01 00 00 06 34 0c
	01 04 01 00 00 0b 18 3e
	01 05 01 00 00 0e 31 34
	01 06 01 00 00 12 31 32
	01 07 01 00 00 17 10 48
	01 08 01 00 00 1a 1f 2f
	01 09 01 00 00 1e 33 37
	01 0a 01 00 00 21 37 25
	01 0b 01 00 00 24 38 34
	01 0c 01 00 00 28 33 2a
	01 aa 01 01 00 2b 27 0c
6:10:58 PM	#28 SPTI -1033 File SCSIPassThrough.cpp, Line 179
	CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1033)
	Sense Key:  0x02 (KEY_NOT_READY)
	Sense Code: 0x04
	Sense Qual: 0x01
	CDB Data:   0x2A 00 00 02 1D DC 00 00 0E 00 00 00
	Sense Area: 0x70 00 02 00 00 00 00 0A 00 00 00 00 04 01
	Buffer x07420900: Len x80a0
	0xFF FF 00 00 FF FF FD FF 01 00 02 00 FC FF FD FF
	0x03 00 02 00 FC FF FE FF 02 00 00 00 FF FF 00 00
	0xFF FF FF FF 02 00 00 00 FC FF 00 00 03 00 FF FF
6:10:58 PM	#29 CDR -1033 File Writer.cpp, Line 299
	Drive not ready
6:10:58 PM	#30 SPTI -1033 File SCSIPassThrough.cpp, Line 179
	Sense Code: 0x04
	Sense Qual: 0x01
	CDB Data:   0x35 02 00 00 00 00 00 00 00 00 00 00
6:11:04 PM	#31 Phase 38 File dlgbrnst.cpp, Line 1760
	Burn process failed at 24x (3,600 KB/s)
6:11:04 PM	#32 Text 0 File SCSIPTICommands.cpp, Line 254
6:11:07 PM	#33 Text 0 File Cdrdrv.cpp, Line 10538
6:11:07 PM	#34 Text 0 File SCSIPTICommands.cpp, Line 411
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 11/3/2005 3:00:00 AM
File 'Drivers\PXHELP20.SYS': Ver=3.00.11B, size=46080 bytes, created 11/3/2005 3:00:00 AM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
I've discovered that there's actually no problem writing data discs. I just wrote ~600MB of data to a disc without problem. I did this through Windows (select files on HDD-->right-click-->send to CD drive--> then go to CD drive and select "write these files to CD. That went off without a hitch.
I copied my Windows Office disc using Nero's software without a problem.
I can write MP3's via Windows to CD without a problem.
All at 48x.
The only problem I'm having is with copying an audio CD. Using Nero, "copy CD fails no matter what speed I choose.
Using Windows, even if I rip an audio CD to MP3's, then attempt to burn as an audio disc, it fails (I'm ensuring that the files, once converted to .cda don't exceed the capacity of the disc either).
What would be causing it to resist copying music, but allowing data (including MP3's)???
Universal Remote
Sony locationfree tv or Slingbox
