The kit Skyvision sells has a 24 pole magnet. That is the design I copied when I made my own.How many magnets should one have for top performance and accuracy?
The one on your dish and the last one I got is the OEM Birdview kit which has less magnets.
You could douse it with some solvent and scrub it with a small brush, but you would have to grease it well when finished. I use White Lithium Grease. Comes in a spray can or you can get it solid.It's pretty nasty in there. The grease has a lot of dirt mixed in and is caked on all around. I plan on scraping and blowing out most of the grime as best as I can then grease it up with what I think is called "White Grease" if that is the best I can use?
The split is for using plastic so that you can take it off the mount. If using aluminum just have them make a screw on section maybe with a hinge, so you can slip it on and then put on the closing section.I'll follow those instructions, they were what I had already been thinking. What is bothering me is what you say of having a split in it.
My BUDs are all at least 25 feet apart so they don't interfere with each other.Right now my two poles are about 11' feet apart.
Good Luck!!
