It's in the same loction.
Be sure you have the proper LNB setup in the Sat Setup Menu.
L.O. 10750
L.O. 10750
What LNBFs are you using? The superdish 105 should work for WSTV, but if you're swapping a circular & linear then maybe they are not in the exact same position on the dish. You obviously can't get echostar 129 with the 105 LNBF so it would be good to know what you're doing.got it. its still not happening. any more Ideas?
I am not swapping lnbfs, maybe I am on the wrong sat. But in the upper right hand corner of the screen is says 129 echostar. It usually only does that to show which sat I am looking at. your saying 129 echostar doesnt do linear at all right? blind scan shows some abc, fox, nbc pay channels. Using a dp lnb might be the key to finding it though if I am on the wrong sat. I will give that a try. Any more ideas? Jason
You are aimed at a Satellite that has active TP's. But in your setup menu you must choose an active (and strong) TP. Then read the Signal Quality, that SQ will help you tune the dish. Follow that with a scan and choose a weaker TP for the finale tweaking of the dish & LNB.Arent I aimed at an active tp if I can blind scan channels in?
It may seem odd but I am using the FSS not the dp like you suspect. No switch is involved.
