Here's the plan, Kevin....I will pull the bushing from my mount within the next couple of days and send it to our resident Birdview guru, Linuxman. He will take it to his machinist and get you some measurements and pics.
I just finished putting up my birdview solid. When I was cleaning up the upper pivot/rack gear I found the offset sleeve bearing completely seized on the pivot so the sleeve was pivoting on the frame. This sleeve is for setting the gear spacing with the worm gear. This bearing should be held in place on the frame by two set screws, the pivot/rack turns in it. My dish would turn about half the arch and then seize. The offset bearing on mine was very hard to get off (I used heat and a pipe wrench). I ended up polishing the bearing and pivot with polishing rouge to clean them up and get it working again. This fix will probably require you to pull the whole transmission out.
When you mentioned using the visegrip, it sounded familiar to me.
This sounds very similar to the problem I had..as when the problem occurs, the dish will only move "maybe" an inch either way before seizing up. Through man-handling the dish I am able to get it moving again, but it's only a matter of time before I will get the dreaded phone call from my parent's telling me the dish quit moving.
Can you be a bit more specific as to where the "offset sleeve bearing" is??
Here's the plan, Kevin....I will pull the bushing from my mount within the next couple of days and send it to our resident Birdview guru, Linuxman. He will take it to his machinist and get you some measurements and pics.![]()
No Problem!I appreciate GREATLY the time and expense you all put into this. I will pass this info on to someone that will know how to make one. Also will look more into the "offset bearing" that N0EXE mentioned. Can't do much until the Thanksgiving weekend when I am in the area.
At present, the dish is working normally, despite half of the top pivot bushing being broken off.
.....EDIT: The bushing is now headed back to Phlatwound via USPS First Class mail!
Does anyone have some pictures of where they are fitted?
I've never seen this piece in any Birdview pictures , anywhere.
Some of the dimensions are probably critical, but some would not be, based on its use.
Which surfaces are critical? (needs discussion)
Also, is this the piece some of you have "broken" the lip off?
Brass should bend or deform, but breaking it doesn't sound right.
Has it been determined for sure this is standard brass, all the way through?
(critical question)
Also, are there other pieces to be fabricated?
After reading the comments above, I'm glad the offset gear adjustment is not part of this.
If it had been, and the hole needed to be offset, that could have been accommodated, but since it's not, that's wonderful!
There is some talk of making up the magnet wheel, and I'll look into that in the appropriate thread.
By the way, making one of these brass pieces would cost a lot, but making a bunch of 'em all at once would lower the average price.
Obviously, if you do one "production run", ya need to be absolutely confident the parts are made right the first time.
It would be helpful to get a clue how many folks would want to get one (even as a spare).
For instance, I'd want two. One for a future dish, and one if I were to need to help out a friend in the future.
And that goes hand-in-hand with the eventual price being so reasonable, no one would mind getting in on the deal.
McMaster-Carr
Search for part number 6338K441
It's too long, but otherwise, will it work? (Under $5)
(critical question)
Talked to my old boss yesterday that got me into satellite years ago, an he was a Birdview dealer here in FL. an this is what he told me about that bushing, that it is made from "Oil-lite Bronze" an that type of metal will absorb oil. he also said the best way to lube those bushing is to soak in oil over nite, then lube an reinstall. before yesterday never heard of a oil-lite before, so maybe this is a type of metal that is not that ready avaible anymore.
(critical question)
Oil lite is a sintered bronze product, also called SAE 841 bronze they make it by pressing and heating bronze powder in a mold until it partially fuses, providing microchannels for oil to be stored and to lubricate the bushing/shaft interface. Since it's not a true solid, it's brittle rather than ductile, breaking along the grain boundries. Still in use for many applications like shaded pole motor bushings, it's been replaced by slippery plastics like delrin or graphited nylon in many others. McMaster-Carr has lots of these, perhaps a standard size can be modified
