system fail
pvandy
5
arkansas
Wife had system installed and everything was working a few days later now it is not working. Signal strength across the board is 0. nothing has moved as far as we know. On these systems is there a specific az. and el. or just point south? My experience with sat install is all military and this is obviously out of my norm. Recievers in both rooms in house are not finding a signal. Can you test the LNBF(thanks iceberg for the info on that)?
Yes, we would need your zip code or you can look in the receiver's dish setup menu to obtain the correct azimuth, elevation and skew (If needed) for your specific location. If all units in the home are down, my first guess is the dish moved out of correct alignment; second, check LNB.
where would I look to tell which setup I have? I looked on the end of the LNB and that was the only place I could find model and serial. Other than that it said slimline on the dish, but I dont know that that helps much.
do you have HD?
"it said slimline on the dish"
So wondering if its the new one or older version. But at least we know he has a multi-sat dish setup.
Or like Grydlok said Plug the Power Inserter Back in.
Look for this (prob all black) attached to one of the Receivers..
Cartoon Network Pissing Me Off
Zinwell MS6X16WB Hook up question, New Member here
