I got this dish a couple weeks ago and finally got a chance to set a short 3 1/2" pole to put it on. I intend to put my 1.2 Prodelin on that pole when I find/build a mount for it, in the meantime the Paraclipse Hydro will reside upon it.
This dish is spun aluminum, approximately 63" in diameter and in pretty good condition. When I got it, it had a huge plastic cover on it, but I took it off.
It had a junk actuator on it, so I swapped it for a good 18" Superjack from the boneyard, hooked it and the LNB (but not the polarotor) up to my spare Toshiba TRX-1800, ran the dish up to the apex and aimed it towards due south. I didn't touch the elevation or declination as it came from about 40 miles south and west from me, figured it should be close.
Ran the dish to the west a little and soon had the ABC/Disney slate on 99W with minimal sparklies, ran it further west and was able to see the Classic Arts channel and EWTN on G15, but they were very snowy. Tried hooking up the polarotor after that so I could change polarities/adjust skew but it didn't respond, not sure what the issue is there, yet.
Then I ran the dish back to 99W and hooked up a CS6000 to attempt digital reception. After a blindscan I had the Caribbean nets at 70%, and the MyTVs at 87%, not bad for absolutely no tweaking.
I have an SatAv SL1P - GEOSATpro SINGLE STANDARD KU PRIME FOCUS LNBF that I was considering putting on this dish, but the specs say it is matched for F/D ratio of
0.5 - 0.7
What little info I have been able to find for this dish leads me to believe it has an F/D ratio of .39, and I think most prime focus dishes typically run in the range of .25-.40. I don't understand why the SL1P says it is designed for a prime focus dish with those kind of specs, can anyone explain that? I gave a whole $5 for it in SatAv's last blowout sale so I'm pretty worried about it.
Also wondering if I should paint this dish, it's very reflective and don't want to fry my electronics?
0.5 - 0.7
